Bronco II Ford Bronco II
gear ratio
Old Mar 10, 2001 | 10:18 PM
pee wee's Avatar
pee wee
gear ratio
Old Mar 19, 2001 | 04:49 PM
ryno421's Avatar
ryno421
gear ratio
Does anyone know for sure what the original gear ratio was in a 1985 bronco II?
Old Mar 19, 2001 | 10:28 PM
tomk89xlt's Avatar
tomk89xlt
gear ratio
You need to look on the tag on the gear cover. Most were 3.45.
Old Mar 25, 2001 | 09:10 PM
rcriverclub's Avatar
rcriverclub
gear ratio
by 89 my owners manual confirms it is on the door tag as well. i looked on mine and it was there.
Old Aug 1, 2001 | 12:06 AM
broncoIIGT's Avatar
broncoIIGT
gear ratio
3:73 positive..
Old Aug 1, 2001 | 12:07 AM
broncoIIGT's Avatar
broncoIIGT
gear ratio
3 73 ratio
Old Aug 3, 2001 | 06:19 PM
josh3972's Avatar
josh3972
gear ratio
Look on the sticker on the drivers door under axle you should have one of the following:
42=3.45
44=3.73(most common)
47=4.10
If there is a "D" in place of the first number then you have a factory limited slip.
D4=3.73 limited slip
D7=4.10 limited slip
