1996 f150 overdrive light flashing, no speedo, no odometer
Old Mar 21, 2026 | 07:42 AM
jegsperformance's Avatar
jegsperformance
7th Gear
1996 f150, 5.0, 4R70w. Code was P0500 (vehicle speed sensor a circuit)
Ive changed the VSS on the tail shaft, the sensor on the rear diff. Still same problem
. my scanner tells me my speed and rpm’s while driving but still no speedo, odometer and od light flashing. Checked all fuses and they are all good. Could it be a bad psom? I’m out of ideas.
Old Mar 21, 2026 | 08:20 AM
1Butcher's Avatar
1Butcher
Grab a DVOM and check the signals at the PSOM.
This is a very common issue, there are probably hundreds of threads with your problem. Spend a little time researching and perform some tests.
Old Mar 21, 2026 | 08:54 AM
Mudsport96's Avatar
Mudsport96
As bizarre as it sounds... does your dome light work? I have heard of that causing speedo issues because they are on the same circuit
Old Mar 22, 2026 | 06:01 AM
jegsperformance
7th Gear
Yea the dome light works. The third brake light is out though
Old Mar 22, 2026 | 06:17 AM
tjc transport's Avatar
tjc transport
i ain't rite
fix the third brake light and you problems may just go away.
Old Mar 22, 2026 | 06:50 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Unfortunately, the 3rd brake light out wont cause the speedometer to not work. It may mess up with the converter locking, and needs to be fixed, but it's not the main issue.
Old Mar 22, 2026 | 01:11 PM
tjc transport
i ain't rite
good to know. as my only vehicle with a third brake light is the 2021 F150, i dont know much about the issues the light being out causes other than what little i read here.
Old Mar 22, 2026 | 02:33 PM
rla2005's Avatar
rla2005
Is the odometer blank or just not registering any new mileage?
If it is blank then you need to verify power is getting to the PSOM, Fuse 8 and Fuse 18. If that is good, then you most likely have a failed PSOM. Look for signs of missing or burned components.
If the odometer does activate then you need to check for the VSS pulses into the PSOM.
Old Mar 23, 2026 | 04:18 AM
jegsperformance
7th Gear
Odometer is just blank
Old Mar 23, 2026 | 06:34 AM
rla2005's Avatar
rla2005
Here is a diagram of the VSS circuit including the PSOM:
Old Mar 23, 2026 | 10:35 AM
jegsperformance
7th Gear
That rear axel sensor in that diagram is the vss? That should be on the tail shaft of a 96 truck
Old Mar 23, 2026 | 01:41 PM
rla2005's Avatar
rla2005
Yes it is.
Incorrect. That is the Output Shaft Speed (OSS) sensor. It has nothing to do with the speedometer/odometer operation.
Old Mar 23, 2026 | 08:57 PM
1Butcher's Avatar
1Butcher
I swear the sensor on the transmission is for the transmission computer. The axle is for the Speedo/Odo/ABS.
I believe the E4OD did not have that sensor and relied on the VSS to determine that the output shaft speed was.
Old Mar 24, 2026 | 06:55 AM
rla2005's Avatar
rla2005
The E4OD transmission never had an OSS.
The Output Shaft Speed (OSS) sensor does feed information to the PCM. In turn the PCM uses that information as described in the diagram below. The OSS is tied to PCM Pins 6 and 84.
Old Yesterday | 11:02 PM
bobby69420's Avatar
bobby69420
2nd Gear
i have that issue where my odometer and speedometer don't work and my dome light it out
