I'm going to try to explain this as best I can. This does not occur every time......
At startup the windows won't function, the dome light won't work, neither will the radio or climate controls. Other electrical functions seem to work fine. After "approximately" a minute all of the above mentioned powers up and works fine.
I replaced all of the relays below hoping it would resolve the issue. I figured it couldn't hurt considering they are all over 20 years old. Still no change.
Any help you guys can offer is very much appreciated. I am NOT a Tech so please explain it to me like I'm 5 . Thanks in advance!
sounds like the Accessory Delay Relay in the instrument cluster. My 02 has a bad solder joint on the relay, a quick smack on the dash and everything works for several months.
