Electrical Issue
Old Jun 24, 2022 | 07:18 AM
SC_Dave's Avatar
SC_Dave
Electrical Issue
I would appreciate some help with diagnosing this intermittent issue.
Once or twice out of say 10 times after starting my engine for 10-15 seconds my windows, radio or AC won't work. There may be other electrical items that don't work, these are just the ones I know about. At the end of the 10-15 seconds everything works normal from there on.
I'm baffled. Thanks in advance for your help.
David
Old Jun 24, 2022 | 07:41 AM
Listor's Avatar
Listor
I would be interested in this as well, once in a while as i fire up the truck my windows and radio will not work, after several second they come on and everything works as it should
Old Jun 24, 2022 | 08:05 AM
manicmechanic007's Avatar
manicmechanic007
SC_Dave and Listor,
Both of you,
You need to interrogate the ignition switch
Early Taurus was the worst for this
After the key returns from start and say the radio or HVAC does not work
Wiggle the key around ever so slightly (as to not turn the vehicle off)
See if the accessories do not magically start working
Indicating your ignition switch is faulty
Replace the switch and done (easier said than done)
Good luck
Old Jun 24, 2022 | 08:56 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
If it turns out the contacts are what are at fault within the ignition switch, check out the thread below.
Link: Ford Ignition Slide Switch Testing (Not the Key Cylinder)
You may be able to use some CRC Electrical Contact Cleaner or some DeOxIt as it has claimed to be the best thing since BLT's...
Link: DeOxIt clicky clicky
Old Jul 7, 2023 | 02:24 PM
SC_Dave's Avatar
SC_Dave
Resurrecting this thread:
I replaced the Ignition Slide Switch and the Key Cylinder Switch. Still having the same issue. It's very odd but that seems to be the order of the day for me right now. I would appreciate and suggestions especially from anyone who may have cured this problem.
David
Old Jul 7, 2023 | 05:06 PM
manicmechanic007
Was it a Ford ignition switch?
Lets go over your problem once again
You start the truck and have no accessories (intermittently) for several seconds?
Perform a wiggle test on the wires at the ignition switch
You had the switch out and replaced
You checked for pulled out or loose pins?
An intermittent power feed into the switch or the switch itself is about the only part that would cause your symptom IMO
A bad ground is possible, a relay is possible
Need to look at a power and ground distribution diagram in the EVTM and see what relays are in the circuit for the radio & HVAC
Old Jul 7, 2023 | 07:12 PM
helifixer's Avatar
helifixer
David
failing GEM module.
my 02 does the same thing.
Old Jul 7, 2023 | 09:42 PM
udsuth78's Avatar
udsuth78
If I remember correctly and don't have my wires crossed (no pun intended)there is a fues tied to this. Accessory delay circuit or something like that in the fuse list. Could be as simple as some corrosion on the fuse or contacts. Or I could be in left field and thinking of a different vehicle entirely.
Old Jul 8, 2023 | 07:38 AM
manicmechanic007
Failing GEM is sure a possibility
Not sure GEM is in charge of the radio circuit though
Old Jul 8, 2023 | 07:59 AM
bigb56's Avatar
bigb56
Notice that all the trucks having this issues are 2002's. 2002/2003 trucks don't have a GEM, they have a VSM and a hybrid electronic instrument cluster that contains the accessory delay relay. The VSM and the hybrid cluster work together and the radio and windows are just one of the things that can be affected by either component failing.
Old Jul 8, 2023 | 08:36 AM
kbeefy's Avatar
kbeefy
I agree with the accessory delay/instrument cluster suggestion.
jchf3700
Electrical Systems/Wiring
Apr 26, 2019 08:55 AM
azgator
Jul 3, 2016 10:50 AM
Shaun Fed
6.4L Power Stroke Diesel
Sep 1, 2012 12:08 AM
tilelayher
2009 - 2014 F150
May 29, 2012 08:45 AM
Texas Ex
1978 - 1996 Big Bronco
Mar 16, 2004 08:25 AM
