Rattle in the front driver side
Old Dec 10, 2003 | 07:30 AM
F_150's Avatar
F_150
Question Rattle in the front driver side
Not sure where to start. When I bought the truck a year ago I had a simular rattle from the driver side. It turned out to be a loose shock. Recent trip to Mech's, for water hose issue, had rattle investigated....they had no clue. Could someone clue me into where to start looking. I intend to put it up on jacks this weekend and start that journey into F-150 front-in trouble
Old Dec 10, 2003 | 01:27 PM
First Ford Truck's Avatar
First Ford Truck
I just noticed my spring was broke while doing my first oil change.
Old Dec 10, 2003 | 03:44 PM
415dave's Avatar
415dave
F_150, is it a constant rattle or a clunk once in a while? Is it 4wd? There are several things it could be, but if you give us a little more info, we might be able to narrow it down.
Old Dec 10, 2003 | 06:20 PM
pj'sbucket's Avatar
pj'sbucket
my rattle is gone.... it was the right hand motor mount.
Old Dec 10, 2003 | 06:25 PM
iron eddie's Avatar
iron eddie
There are are several things that it could be. (As quoted before) but I am going to take a shot in the dark and say check out the radius arm bushings. They do go bad and are easily overlooked. But it is hard to say without more info.
Iron Eddie 94 Brilliant Blue f-150 XLT BIG SIX
Old Dec 11, 2003 | 07:14 AM
F_150's Avatar
F_150
Rattle.....follow-up
Thanks for the info thus far..... I have a 2WD, 1993 F-150, 5.0 The rattle is continious as long as there is some roughness in the road. Don't hear anything on perfectly smooth roads, but we all know those are hard to find. You can here the rattle as well as feel the vibration through your feet. I tend to think it might be either a driver side shock or spring..but that is just a guess.
Old Dec 11, 2003 | 11:23 AM
90ebbronc's Avatar
90ebbronc
Hey yall, when u get done helping F150, please help me out as well. I have a rattle up front as well, but its coming from under the dash and i cant pin point it. My speedometer works great, and the rattle only occurs at 35mph and faster. My fuel gauge stays up until it warms up, but that shouldnt be anything to rattle. It seems like it has gotten worse over the past week or so, cause it sounds louder. Its already loud enough where u cant talk normal volume. It doesnt sound like a pen or bolt or anything, cause its to loud. Any hints?
Old Dec 11, 2003 | 12:34 PM
oldstylefseries's Avatar
oldstylefseries
Hey f_150,
Had a similar problem on my 2wd f-150. Could feel it in my feet. Had this problem TWICE. First time, it was ball joints. Second time it was a loose shock. The loose shock one was hard to find. If I grabbed the shock, I couldn't feel anything. But I went ahead and tightened the bottom bolt anyways, and the problem went away.
Hope this helps.
Old Dec 22, 2003 | 10:29 PM
Idaho Charley's Avatar
Idaho Charley
Don't overlook the jack and lug wrench as a possibility if they are still mounted on the fender fire wall.
Old Dec 27, 2003 | 08:43 AM
Tye Rod's Avatar
Tye Rod
Post
Sounds like the radius rod bushings, if that's case you will need a wheel alignment afterwards, radius rods effects caster...
Old Dec 27, 2003 | 09:21 AM
RicA's Avatar
RicA
I just went through this with my '89 F-250. It drove me nuts, which some would say is a short trip. I had it up on stands, everything you could imagine. I am a licensed H.D. Mechanic and it took a body man to show me.. The bolt holding the fender at the bottom rear in front of the door was slightly loose. It felt tight but that was just rust. I felt the vibration through my feet and of course heard it. Only on rough road when the body would flex. Good luck.
Old Dec 27, 2003 | 09:48 AM
78f3504x4's Avatar
78f3504x4
I had a rattle for quite sometime in my 94, drove me nuts, and it turned out to be the washer underneath the bolt holding the coil spring on my front driver's side. Coil wasen't loose, the nut/bolt rusted in place just enough to rattle the washer.
supercrewser1751
2009 - 2014 F150
21
Mar 23, 2016 06:46 PM
79ranger150
Aug 23, 2014 08:13 AM
tbug99
2004 - 2008 F150
Sep 11, 2012 11:17 PM
davew250
Mar 26, 2008 06:54 AM
New To Ford
2004 - 2008 F150
Feb 22, 2006 12:58 PM
