opinions please!
Old Mar 23, 2026 | 09:41 PM
  #31
oldbird1965's Avatar
oldbird1965
No, I haven't Tom. I'll keep that in mind if it fails to run good.
Old Mar 24, 2026 | 05:24 AM
  #32
tjc transport's Avatar
tjc transport
i ain't rite
that is always my first go to on both diesel and gas engines when i get a dead/misfire cylinder i cant easily diagnose.
Old Mar 24, 2026 | 09:40 AM
  #33
oldbird1965
I'm holding off on that because it passed the cylinder contribution test which tells me the injector is OK? Its the buzz test that throws the code of low current on the cyclinder #3 indicating bad wiring. If it doesn't run good after I get done with the new UVC wiring I'm thinking I might need a new engine wiring harness because I couldn't find anything wrong with the wires when I took it apart.
Would a SD wiring harness work? That way I don't have to bother with changing the VC plugs from OBS to SD.
Old Mar 24, 2026 | 04:18 PM
  #34
oldbird1965
I have something positive to report. I finished up the uvch on the passenger side, started it up and it ran smooth. Looking down on the wire loom that splits off to the vc plug I gave it a shake. The motor started running rough! I moved it around and it smoothed out. Drove it a couple blocks and it ran good. Tomorrow we go to Vegas for a Doc appointment and then Thursday morning I'm taking the 5er two miles down the road for my warranty work. After all that I'll cut into that part of the wire loom and see what I can see.
Old Mar 26, 2026 | 05:13 PM
  #35
oldbird1965
I unwrapped the wire harness on the passenger side and I 'think' I found the problem. #3 injector wire plug where it was soldered to the harness had a bare spot on it that I believe was shorting out on the foil wrap and bare wire that goes around the wrap. I'm thinking about soldering in a new pigtail or just cover that bare spot and go for it? There is also a bare spot on one of the glow plug wires, maybe I stretched this pigtail loom at one point, IDK. While I was unwrapping the wire harness I would start it up and wiggle the wires and when it ran rough stop and unwrap some more. I got it down to what is in the picture and I can now wiggle the whole thing and it keeps running good. What is the purpose of the foil and bare wire wrap? Radio interference or what? So now I can cover the bare spots with tape or solder in a new pigtail, that is the question now!
Old Mar 26, 2026 | 08:15 PM
  #36
fordman67's Avatar
fordman67
I hope that fixes it!! Looks like a smoking gun for sure tho.
Old Mar 26, 2026 | 10:04 PM
  #37
oldbird1965
I hope so too Aaron! They fixed my 5er so I'll go get it in the morning if the old OX lets me! Good luck on your projects. Thanks
Old Mar 27, 2026 | 04:57 AM
  #38
867.309's Avatar
867.309
Great thread, thanks. Wonder how many UVCH pigtails were installed in trucks over the years by people who never even knew high voltage was involved.
"Check for previous, aging repairs" should be chiseled in stone on a checklist somewhere.
Old Mar 27, 2026 | 09:56 AM
  #39
knottyrope's Avatar
knottyrope
The foil is to act like a ground for stray current
The injectors fire at 120v and that pulse can act like a transformer to the other wires, firing another injector for a split second.
If all connections are tight, wrap each connection in E tape for now and then redo pig tail when you can.
Old Mar 27, 2026 | 10:09 AM
  #40
Hit Man X's Avatar
Hit Man X
I have great luck with liquid electrical tape, I would seal them and then rewrap with the foil as required.
Old Mar 27, 2026 | 01:39 PM
  #41
tjc transport
i ain't rite
my thoughts too. put heat shrink tube on wire. two or three coats of liquid tape, then slide heat shrink over the dried liquid tape and seal it up
Old Mar 27, 2026 | 07:12 PM
  #42
oldbird1965
Sounds good guys BUT, a lot of that foil fell apart when removing it. Is it just aluminum foil, household stuff? I've got some of that liquid tape stuff, sounds like a plan. After going to four doctor offices today, one for me and the rest for my wife I just didn't want to get into the heat again. Getten lazy in my old age! lol
Without cutting the wires I didn't think you could use heat shrink over wires. Just cut it length wise and put it on the wire and add heat??
Old Mar 27, 2026 | 07:24 PM
  #43
tjc transport
i ain't rite
nope, you need to have the wires separate to use heat shrink. unless you can unpin the connector and remove the wire, put the het shrink on, then repin the connector.
Old Mar 27, 2026 | 09:32 PM
  #44
oldbird1965
I'll look at the vc plug and see if that's possible.
Old Mar 28, 2026 | 08:13 AM
  #45
Hit Man X's Avatar
Hit Man X
Alliant sells new connectors alone with a depin tool, I think I posted the photo of it in here once upon a time.
I did buy a depin kit of different sized tools from ebay a while back, worked well.
