Help with wiring
Old Mar 13, 2026 | 08:10 PM
Nitro1168's Avatar
Nitro1168
Help with wiring
1970 f100 360. The plug for the voltage regulator. Can someone help me with this mess.
Old Mar 14, 2026 | 01:06 AM
Green72F250's Avatar
Green72F250
If you are wanting to replace the plug, NPD sells one that you can splice in your wires.
Alternator Voltage Regulator Connection Repair Harness - #14R290-1A - National Parts Depot
If you are just wanting to clean up your existing plug you might try some electrical contact cleaner to see if that helps.
Old Mar 16, 2026 | 01:15 AM
1TonBasecamp's Avatar
1TonBasecamp
Is that three yellow wires that I see? Interesting. Although, with the empty space at the upper end, I’m guessing your truck has an ammeter instead of a battery light?
If that’s the case, then the lower wire should be in the “F” position. And that is your Orange field wire running directly between the regulator and the “FLD” terminal on the back alternator.
Next step up is the red wire, which was originally green with a red stripe and should go to the “S” position. This has 12 V with the ignition switch in the ON position only.
third up should be the “A“ position and is usually populated by two yellow wires. One is just a short pigtail going to a radio noise suppression capacitor. That’s probably the one with the black push connector that is just visible in your picture. The other main yellow wire should have full battery voltage at all times.
The “I” position of the regulator and connector should be blank/empty
If your truck has a battery lamp after all, and no ammeter, the wiring is slightly different.
Old Mar 16, 2026 | 08:31 AM
Nitro1168's Avatar
Nitro1168
Thanks I appreciate it. That helps
ChrisCCC
Oct 8, 2021 05:34 PM
jsmithff
Sep 28, 2021 01:55 PM
stloza
Feb 10, 2008 08:27 PM
78fordman
Electrical Systems/Wiring
Nov 29, 2003 04:34 PM
