Let us know what you think when you get them. Looks like a bit firmer foam which couldn't hurt.
I've been thinking about changing my name to Justin Case.
C0TB-8112130-A - PAD - TRANSMISSION COVER WEATHER - (foam) - 2" I.D. x 7" O.D. x 2" thick
Trans leak = new clutch...new starter....new foam...new carrier bearing...new trans mount....new rear main seal.... new ring gear on thw flywheel. Paint the trans cover....paint the cross member... paint the shifter rod...
