no power please help
Old Mar 8, 2026 | 04:03 PM
abess350's Avatar
abess350
2nd Gear
Here is my problem . 97 7.3 not getting any power to dash. nothing is coming on.
the story behind it
before winter drove it with minimal problems. something was draining batteries ( im assuming all the extra stuff put on by previous owners ). if i let it sit for more than a week batteries would be dead. after one battery lost a cell i purchased new ones and all good. right before winter i drove it home from work and then next day no power at all . so i thought maybe another battery died or cell died. pulled the truck in garage over winter. i have had batteries on a tender all winter . hooked back up and nothing again. took batteries to get checked at 2 different places and and both say good. i replaced all battery cables thinking maybe some were bad and while do so i took off all the extra stuff that someone else put on such as extra lights and etc. so with batteries fully charged and brand new cables all the way around im still not getting any power to dash. can anyone help me out with this. what should i be looking at ? what should i be testing ?
Old Mar 9, 2026 | 10:00 AM
Hit Man X's Avatar
Hit Man X
May be a crappy ignition switch, BTDT with these. Only recommend Motorcraft, the aftermarket never seemed to have all positions operational
Alts also can cause a drain, tried a drain test? 20-30mA is about it. Dealt with that for years on an IH Scout2
Also, bought a new batt for the black Burb. Always weak aka bad brand new
Old Mar 9, 2026 | 01:12 PM
knottyrope's Avatar
knottyrope
Not even head lights?
Did you clean the battery terminals inside and out?
Old Mar 9, 2026 | 02:08 PM
farmert's Avatar
farmert
Take a look at the fender mounted starter relay. Ford used the relay for a junction for power to the cab. Make sure the nut us tight on the side that has multiple wires on it.
Old Mar 9, 2026 | 05:19 PM
abess350's Avatar
abess350
2nd Gear
not even headlights and yeah terminals are all good
Rockinfigs
All Things Towing
Jul 27, 2023 10:55 AM
95fiveoh
28
Jan 25, 2020 09:21 PM
BPofMD
All Things Towing
30
Aug 3, 2016 09:45 AM
swampfire79
Feb 11, 2012 02:40 PM
Surf Fishn Truck
Dec 31, 2004 08:05 AM
