A shocking question.
Old Mar 8, 2026 | 10:55 AM
Ol' Grouch's Avatar
Ol' Grouch
I like this forum. Lot's of activity from people who seem to have a lick of common sense. I've been on other forums that there are people who read a book once, or looked at their phone, and know more than I do on the old stuff. Here at least folks know which end of the wrench to use.
To my question. I'm looking at the mismatched plug and coil wires and when I popped the distributor cap off, I noticed a lot of corrosion and wear for the contacts. Hence, my question. I know, shocking, right? What is the general consensus on ignition parts to use? What are the best current crop of plug wires to use for a nice hot spark without ghost flashes? Can I get a cap and rotor with brass or copper electrodes? What's a good hot plug to use?
When this truck was new, I knew what was good but with 40 years of advancements, what's good now? The engine runs okay, but it isn't really happy. It can definitely run better. Part of that is the slop I've found in the timing chain, but it definitely needs a good tune up.
Old Mar 8, 2026 | 11:37 AM
Max Capacity's Avatar
Max Capacity
I trust my local NAPA to help me choose the best parts. Some of the guys there have been there for over 15 years that I've been going to this NAPA.
Echlin, Stanndard, don't buy the cheap part. I did find, I had to open up the bolt holes on the Standard battery ground cable. Not a big issue.
Most of us stay with the copper plugs, Again, buy from a trusted place.
I have Belden spark plug wires, they have been there for a long time, I mean like 25+ years.
Old Mar 8, 2026 | 02:53 PM
FuzzFace2's Avatar
FuzzFace2
^^ what he said ^^
Copper plugs, none of them fancy ones as some have had issues with them and others not and they all have been hard to find with the problem was till the plugs came up.
Wires, I did not go for the cheapest ones but also not the big dollar one either, been going on 6+ years now.
Cap & rotor I dont know if mine are brass or not but they have been working 2 years now as I replaced them, with plugs, when I had a miss under load, it was a fouled plug.
I dont have a problem going to one of the big parts stores, I got one within walking distance if need be and I get a discount with my car club membership.
Thing is I look up all parts online first so I know what they offer and have in stock and I hardly ever go for the cheapest one unless I need to get back up and running NOW!
But with the pickup, SUV, and car I can drive plus the wife's car I am hardly ever in a rush.
Dave ----
Old Mar 8, 2026 | 03:02 PM
Franklin2's Avatar
Franklin2
You might be able to get a cap with brass terminals from rockauto. They sell closeouts, and may have some at a reasonable price.
Old Mar 8, 2026 | 08:49 PM
Ol' Grouch's Avatar
Ol' Grouch
Standard ignition parts were my go to for years back when I raced. The brass parts often took a slight miss out of an otherwise good running engine. I'm thinking about either copper or platinum plugs. I like Champion but rarely use them on carbureted engines as if they flood, they are shot. Then again, some of the stuff we did "back in the day" wouldn't fly today. The transmission is my first priority, then I'll track down the other things. All the other stuff I'm doing is just while waiting on parts.
Old Mar 9, 2026 | 04:13 AM
My4Fordtrucks's Avatar
My4Fordtrucks
I use a distributor cap with brass terminals
Ford Motorsports wires
and usually Motorcraft copper plugs in everything but in the ‘89 F-150 I have the Autolite copper plugs recommended by AFR.
Old Mar 9, 2026 | 05:32 AM
s1120's Avatar
s1120
I do like to use a cap with the brass terminals. With even good brands being kinda cheap these days, you just need to spin the wheel and hope. As for wires. I really prefer Taylor wires on most things. Really well made, and while not cheap, wont break the bank either. That being said, Ive also had great luck with the cheaper sets ive gotten from Amazon. Maybe ive been lucky with those? Who knows. Plugs? Copper core Motorcraft or Autolite. Save the fancy stuff for the late model stuff.
Old Mar 9, 2026 | 06:46 AM
FuzzFace2's Avatar
FuzzFace2
Go copper not the platinum.
Our trucks were made to use copper and the newer type plugs have been known to cause problems.
Maybe not right away or maybe never but why risk it chasing your azz trying to find why it runs like crap only to put copper plugs in.
Again you may get lucky and they would be ok then again???
I also go with the factory heat range. Now if it was a oil burner and kept fouling plugs then I may go hotter.
Just my .02
Dave ----
Old Mar 16, 2026 | 09:45 PM
Ol' Grouch's Avatar
Ol' Grouch
Got some copper plugs and other ignition parts. I think they are either Autolight or Motorcraft. Back in the day, I used Champions but they had a habit of flooding out and never starting again. However, I got to looking at my plug wires. Either this truck was service at a Ford shop the last tune up or it has the factory wires. Each one is marked with the cylinder location as well as the Ford logo.
I'm going to wait until I swap the transmission to see what else needs attention when I start driving it. I've got the transmission and all the stuff to freshen it up. I'm just waiting on some warmer weather. It was 75 yesterday and the high today was 31.
Old Mar 18, 2026 | 07:14 PM
BMWZ4Mguy's Avatar
BMWZ4Mguy
In the last year I got a 1986 5.0 EFI running, long saga, but I can say, that I used a lot of Standard Motor Products parts, and none let me down. They have become my go to for electronic parts. That said, I did burn out a Motorcraft TFI ignition module in less than a couple hours of running time, moved it to the fender with a heat sink and CPU fans, and put in a cheap SMP module… its been running with that for the past 6+ months. Summer is coming though.
Old Mar 18, 2026 | 08:35 PM
Ol' Grouch's Avatar
Ol' Grouch
FoMoCo and Chryslers of this vintage didn't like heat. GM was a little more stable. Back in the day, I'd fill a sandwich bag with ice from a cooler or get a fountain soft drink, heavy on the ice, and use that is the baggie to cool the brain box.
My truck fires right up and runs pretty good. The guy I got it from, his son had trouble starting it. He'd never driven a carbureted engine before and didn't know how to set the choke. I'm having trouble with it dieseling but I suspect the timing chain has some slop. Once I put the new (well, used but hopefully good) transmission in, I'll tear into the water pump and timing chain. Everything looks factory. The heater and water pump bypass hoses are OLD, dry rotted and really soft.
My new cap and rotor showed up from Standard and they have nice brass inserts.
Old Mar 19, 2026 | 05:50 AM
FuzzFace2's Avatar
FuzzFace2
I dont think I have seen a bad chain cause dieseling?
Timing jumping all over the place, maybe lack of power but you would have to see that from a bad chain to a good one and even then maybe not.
99% of the time for dieseling is the idle speed too high.
Now if it has to be that high for when in gear you may want to look into a idle solenoid to fit on the carb.
You set the idle speed with the solenoid and when you shut the motor off the solenoid drops back to the carb idle speed that is lower speed and no more dieseling.
Same solenoid used on AC cars & trucks to kick the idle speed up when the AC is on.
Dave ----
Old Mar 19, 2026 | 10:06 AM
Ol' Grouch's Avatar
Ol' Grouch
Dave ----
It depends on if someone has messed with the timing. Back when I ran a shop, I saw all sorts of things where somebody thought "I can fix that" but couldn't. Usually it was something basic. On Fords and Chrysler big blocks, the distributor is up front and folks mess with them.
Timing chains have gotten better metallurgy over the years. In the 1950's, if you got 50-60,000 miles you were doing good. By 1970 it was up to around 100,000 miles. By the 80's it was 125-140,000 miles. I've got 137,000 on the truck so I figure it's about due for one. On newer engines, those numbers go out the window. I've put one set of cam phasers in the three valve engine. That's all I'll EVER do.
MountainManRobb
Jun 28, 2024 11:19 AM
RadF250inSC
Jul 6, 2023 10:10 PM
72Heirloom
Jul 22, 2022 11:34 AM
Leudog16
Oct 25, 2010 12:34 AM
Hellbore
May 18, 2006 02:17 PM
