Stalling issue
Old Mar 6, 2026 | 05:12 PM
Norton manx's Avatar
Norton manx
5th Gear
Stalling issue
Hello I have a 1996 F-250 with a 460 engine that stalls when throttle is slightly pushed and allowed to return. Revs up fine and idles fine. Seem to catch it self sometimes and continue to run. Weird thing is if I remove TPS from throttle body and still plugged into harness the stall problem goes away. Any help would be greatly appreciated. Thank you
Old Mar 7, 2026 | 05:33 AM
90project5.0's Avatar
90project5.0
Test the tps.
Old Mar 7, 2026 | 05:58 AM
Norton manx
5th Gear
Originally Posted by 90project5.0
Test the tps.
The voltage checks are ok and I used one from a running truck and have the same stalling issue.
Old Mar 7, 2026 | 06:08 AM
90project5.0
What codes are you getting?
Old Mar 7, 2026 | 06:22 AM
Norton manx
5th Gear
egr code will check again and let you know thx
Old Mar 7, 2026 | 09:09 PM
90project5.0
The EGR if stuck open can cause stalling issues. If you have a hand vacuum pump, pull vacuum on the EGR and look through the holes on the side. You should see it rise with vacuum and fall when released.
Willzale
May 5, 2024 04:54 PM
Dales F-350
Jan 2, 2010 09:34 AM
bigred00
Apr 6, 2005 08:39 AM
budda919
1978 - 1996 Big Bronco
Oct 3, 2003 06:16 PM
