Need a 12v backup cam trigger
Old Mar 6, 2026 | 10:58 AM
robert kelsey's Avatar
robert kelsey
Is there any place behind the dash to tap a reverse gear 12V signal for my backup cam ?
Trying to avoid getting into the harness under the body or a 20' tail light wire if it's possible..
I was thinking maybe tap the parking aid disable switch but can't find a decent diagram.
Old Mar 6, 2026 | 12:00 PM
John in OkieLand's Avatar
John in OkieLand
IIRC,
down on the shifter linkage near the floor, there is a Microswitch that is activated when the shifter is in Reverse.
Old Mar 6, 2026 | 02:07 PM
01__Excursion's Avatar
01__Excursion
Mine was tapped in to the reverse light signal wire at one of the taillights. That's one option.
Old Mar 7, 2026 | 09:59 AM
robert kelsey
Originally Posted by John in OkieLand
IIRC,
Do you remember the color, black/pink maybe
Old Mar 7, 2026 | 03:29 PM
John in OkieLand
IIRC,
that was two years ago, and no I don't, sorry.
I thought it was on this Colored Electrical System diagram,
but I am not seeing it, but you might like to have it anyway.
https://mega.nz/file/3QAwSJwC#mZISWl...fn2eIa8XYKLmE8
Old Mar 7, 2026 | 03:39 PM
John in OkieLand
this is where I found that colored diagram,
he has more that you might want.
https://sites.google.com/site/woodnt...ams?authuser=0
Old Mar 8, 2026 | 09:36 AM
4Kids's Avatar
4Kids
The Struggle Bus¯\_(ツ)_/¯
I think that this may depend on if you have the Parking Aid Module (PAM) option installed in your Excursion. I believe that the power to the reversing lamps is switched on at the Digital Transmission Range (DTR) sensor located on the transmission housing, which then feeds power directly to the reversing lamps. From what I understand, the only wiring path back into the cabin is to activate the PAM module. Perhaps Ford wired all the Excursions this way, even if they had PAM or not???...not sure. You will be looking for a BLACK wire with a PINK stripe (BK/PK) going into Connector C421 Pin #9.
This is the perfect job for the Posi-Tap 12-18 gauge taps. They are awesome for stuff like this!
Old Mar 8, 2026 | 07:00 PM
01__Excursion
What am I missing?
You want to tap in to a reverse voltage signal wire to power the "Backup" camera I guess.
You do not want to disturb any of the body harness from the cab to the rear, and you do not want to run a 20' wire to the taillight?
Where is this camera going to be mounted, in the rear or up front? Is it a wireless camera, or wired?
If the camera is conventionally wired either by signal, power or both and in the rear as expected (license plate/bumper) something has to go from the head unit to the rear for the camera, no?
Old Mar 8, 2026 | 07:58 PM
4Kids's Avatar
4Kids
No. His head unit needs to see 12V to automatically switch the reverse camera on and bring it up on the display when in reverse. This is usually done by tapping into the reverse light circuit. There is also usually setting in the head unit to require a certain duration of power so that it does't turn the camera on when you are just 'passing through' reverse while shifting into drive.
Old Mar 8, 2026 | 10:16 PM
robert kelsey
Originally Posted by 01__Excursion
What am I missing?
Exactly, the coax with 22ga siamese is already run through the interior & cam is mounted on the rear headliner trim. Since the PAM is right there in the RR corner with HVAC, I'm probably going to just tap the black/pink at the park aid module for a trigger, & if I can find a KO+ on that park aid module it'll feed the cam so I can select it when towing..
Old Mar 11, 2026 | 01:45 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
If you need a Headunit trigger (to switch screen), tap off the rearview mirror. See above diagram for the wire # and colors. Black with pink tracer
the rearview mirror has a reverse trigger. this serves to disable the "Auto Dim" when you are backing up. I've been using this for years to trigger my radios.
As far as the camera itself, I tend to use the 7-pin for power and trigger (as needed). it's relatively easy to run a short wire from the 7 pin constant hot (batt charge) or from the trailer reverse wire.
Katoom
15
Apr 25, 2022 09:55 AM
Hummer1
Escape & Escape Hybrid
Mar 7, 2013 09:16 PM
sailmfast
6.4L Power Stroke Diesel
Nov 26, 2011 10:23 PM
SUPERDUTY_untouchabl
Dec 28, 2007 03:52 PM
BroncoII85
Bronco II
Jan 31, 2005 09:06 PM
