Alternator Charging Wire Upgrade
Instead could I cap off the broken end and keep the terminal connected at the passenger battery as that line also runs the glow plugs/AIH (deleted). If so which battery do I run the new + wire to? For a 135 amp alternator what fuse block would you recommend? Personally would rather use a circuit breaker vs rolling with a spare fuse. Maybe there’s a reason besides cost none of the premade kits are set up with a circuit breaker…
Have also seen people adding a ground to the alternator bracket again which battery should I use or it doesn't matter? Have over 15 ft of extra 2/0 wire with plenty of lugs for materials.
Thanks
the amount of modification to the bracket took me about 2 mins running a dremel as I’m replacing the alternator w the same 6.0 style. If you don’t want to grind you could probably use 1 washer per bolt under the case and have clearance.
Retracted my recommendation due to Y2k's casualty...will be looking for my own ideas for fusing/ circuit breakers now.
This component has been redesigned twice by Buss, the manufacturer.
Two prior designs have failed, for different reasons.
While I was careful to avoid the first design when purchasing, I was disappointed to find the second design failed, dramatically, even while not having any of the problems of the first design.
I removed the one that I had, and while I presented (rather than "recommended") my installation in the past, I would now specifically NOT recommend attaching any twin post MRBF holder to the B+ terminal on any alternator, or engine component subject to cyclic vibration.
The failure modality in the first design pertained to how the buss bar plate, stud posts, and insulator were formed, where the structural design was conducive to dead shorts within the holder.
The second design introduced a sharp L bend radius into the bottom conductive plate, which when combined with the modified insulator design, better isolated the fuses. However, it was at this bend radius where the second design failed, separating completely. In my case, it was a live open. (Both sides hot, but not connected, forcing all alternator output through original small gauge OEM charge wire).
I've been intending to do a write up on this, but time has not permitted.
IMO, it does not make any difference which battery you choose, as they are in Parallel with a very large gauge wire/cable.
Been working with electric stuff since 1958, and never found anyone that could prove differently.
