Sponsored by: Real Truck
Push buttons external door lock
Old Mar 2, 2026 | 12:12 AM
BrutusMaximus's Avatar
BrutusMaximus
Trailering
2015 Disel Lariat crew cab . The external push button panel on driver side door does not work anymore and will not reset. Is this a common problem with the panel or more likely to be a wire issue. And is this panel expensive? . Thanks Frank from OZ.
Old Mar 2, 2026 | 06:06 AM
99powerstrokedF250's Avatar
99powerstrokedF250
Depending on the type of keyless entry it is, it may not be wired. Some were wireless and battery operated, and when the battery would die they would no longer function. It will depend on which kind you have as to whether it is a wire issue or not.
I would say that panel itself usually isn't expensive.
Old Mar 2, 2026 | 07:13 AM
BrutusMaximus
Trailering
Ok thanks for the info, will look into a new panel.
Old Mar 2, 2026 | 10:28 AM
INFRNL's Avatar
INFRNL
no batteries. Part number according to the video: BCZ-14A626-AAA
morehouse7
Feb 10, 2024 12:41 PM
charlie.m
Aug 16, 2016 03:27 PM
Bookemdano
Aug 1, 2009 10:44 AM
FordSDF250
Jul 27, 2009 08:50 PM
BEECHBM69
May 1, 2007 01:05 PM
