Motorhomes (Class A,B,C & Super C) F-53/59, E-Series E-350 / E-450 RV Cutaways, Econoline, Transit, Stripped Chassis, Bus Conversions
97 F53 Ignition problems.
Old Mar 1, 2026 | 11:23 AM
Move_N_Man's Avatar
Move_N_Man
Trailering
I've been fighting this problem for over 2 years. On hot days and while climbing hills the engine will start running rough, loose power and die. It has to set with the engine off for at least a couple of hours before it becomes drive-able again. I've replaced 20+ modules, the coil twice and just now the distributor. Still isn't fixed. Am I missing anything other the the ECU? I've been trying to find one of those for a couple of days now (F6TZ-12A650-AJA) since I'm stuck in Yuma because of this problem. Ford parts network shows 'Part Obsolete - 0 Available.' Can't find any information on part interchange. Anybody have any information?
Old Mar 1, 2026 | 11:30 AM
Awar's Avatar
Awar
Have you replaced the crank position sensor? The distributor contains the cam position sensor, so that is new. The thick film ignition module is mounted to the outside of the firewall with a large heat sink. It is a simple ignition system with known heat related issues. They do make a GM style HEI distributor that fits the 460.
Old Mar 1, 2026 | 11:55 AM
Move_N_Man's Avatar
Move_N_Man
Trailering
This is a 97 F53.
Thanks for the reply.
It is the last of the 460's so it doesn't have a crankshaft sensor. I've replaced over 20 of those TFM's in the last couple of years. I can replace one and it still has heat/ignition problem. I even put a new black one on a few days ago when I replaced the distributor.
Old Mar 2, 2026 | 01:11 PM
jimzdat's Avatar
jimzdat
Just thinking out loud - heat could be dealing a blow to the electronics, especially if it's a cold joint that opens up, or something that is expanding/contracting.
I fought a rough idle issue on one a few months ago, turned out to be a bad capacitor in the PCM - and the repair was quick and affordable...check out the link in my earlier thread:
https://www.ford-trucks.com/forums/1...-2500-rpm.html
Old Mar 2, 2026 | 02:06 PM
Move_N_Man's Avatar
Move_N_Man
Trailering
I saw that post. You certainly had a mess on your hands.
I agree that it's heat related. It's mounted to the firewall, under the dash above the brake pedal. On hot days it doesn't take long for it to turn my motorhome into a 12,000 pound boat anchor.
Old Mar 2, 2026 | 07:26 PM
jimzdat's Avatar
jimzdat
Yep - I had the doghouse cover off while doing other work, and was able to lay an old moving blanket over the engine, and basically lay on the floor/engine to get that PCM out....it sucks where they positioned it, especially when one is 6'8" and trying to weasel into a tight spot.
Once I got it out and pulled the covers, it was glaringly obvious which cap had failed - all the magic blue smoke had come out of it.
Given everything else you've done, it might be worth at least doing that check to confirm - beats sitting there in a big box that can't move.
Old Mar 3, 2026 | 09:36 AM
wwhite's Avatar
wwhite
Pull codes, what does it tell you?
Take the EEC-IV out, open the case, take pictures. Looking for blown/leaking capacitors.
Easy fix if that is the problem, quite common, varying issues. Capacitors are like pennies to dollars, and a little soldering.
Old Mar 3, 2026 | 11:17 AM
Move_N_Man's Avatar
Move_N_Man
Trailering
It's not throwing any codes since I put a black tfm back in it. As for swapping out the caps, my soldering iron is in another state and I'm broke down in a parking lot in Yuma, AZ. Ah,the joys of the full-time rv lifestyle. 😉
Old Mar 3, 2026 | 03:34 PM
wwhite's Avatar
wwhite
Are you at least getting the 11 or the 111, meaning all clear, no codes?
Or are you not even getting that?
Old Mar 3, 2026 | 04:15 PM
Move_N_Man's Avatar
Move_N_Man
Trailering
Don't know what it's showing. I threw in the towel yesterday and ordered a rebuilt ECU from a company up in WA. Supposed to be here in a couple of days.
Old Mar 9, 2026 | 07:12 PM
Move_N_Man's Avatar
Move_N_Man
Trailering
Update:
Now it's developed a new problem. No power, getting hot, and it sounds like I have an industrial sized pan of Jiffy Pop under my dog house, cel is also on.
New ecu showed up and I got it installed. No cel, revs fine at part throttle. Go beyond part throttle and the popcorn sound comes back. Have replaced distributor, tfm, ecu, coil and coil wire. Timing was set at 12 degrees with new distributor. Am going to recheck it tomorrow to see if it slipped. After that I'm at a complete loss. I did take the old ecu apart and check the board. No burned traces or bad caps. If anyone is near Quartzsite, AZ and wants to check it out PM me.
Old Mar 9, 2026 | 09:46 PM
jimzdat's Avatar
jimzdat
Check the items that impact air flow as well - particularly the EGR can do many strange things. I realize it's likely hotter than the hubs of hell in AZ compared to OH, but are you able to run it with the doghouse removed, so you can try to narrow down the location of said noises?
Might want to make sure something related to the exhaust manifolds hasn't broken free - all that air pump plumbing that goes everywhere...
Old Mar 9, 2026 | 10:59 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Does it have a catalytic converter? If so, this would be a symptom of a plugged cat.
Old Mar 10, 2026 | 04:48 AM
Move_N_Man's Avatar
Move_N_Man
Trailering
Nope. No cat. Last year without
Old Mar 10, 2026 | 04:57 AM
Move_N_Man's Avatar
Move_N_Man
Trailering
Yes, I can run it without the dog house for awhile. Going to be in the middle 90's late this week so will have limited time to do so though. Thanks for the egr suggestion. I'll see if any of the plumbing is broken. It did develop an exhaust leak recently so I need to address that somehow also.
Kyler16
Dec 8, 2024 02:00 AM
73FordF100
25
Jun 12, 2011 11:51 AM
red rock 78
May 28, 2009 03:29 PM
73F100*8Mile
4 Cylinder Engines
May 13, 2009 09:33 PM
Zebich
Apr 26, 2004 12:29 PM
