1978 - 1996 Big Bronco
New Toy
Old Apr 28, 2026 | 10:15 AM
My4Fordtrucks's Avatar
My4Fordtrucks
Originally Posted by Blurry94
Just curious though, are there people out there that buy factory cast iron intakes and factory carbs? If not, then these pieces are going to the recycler.
Probably. Doesn’t cost anything to list it in the Marketplace section.
Old Apr 28, 2026 | 10:25 AM
stephen.osborne1's Avatar
stephen.osborne1
I'd also try Craigslist or marketplace. 2bbl probably won't bring much, if anything. 4bbl priced right might get a few bucks.
Old May 14, 2026 | 06:37 PM
Blurry94's Avatar
Blurry94
I got $110 for the intake, 2 bbl carb and stock exhaust manifolds on Nerdbook.
Going to pick up the heads from the machine shop tomorrow, and also drop off the block, crank rods and pistons. Looking to go with a set of flat tops with eyebrows, to allow it to make a little more HP.
Going with Fi-Tech fuel injection now. My plan is to replace the tank with one from a late 90's Bronco, OEM fuel pump and FDM through OEM fuel lines, from the tank to the throttle body. Bronco Graveyard has the complete line set, and already have AN adapters to connect the OEM style fuel line connectors to the throttle body.
Old May 14, 2026 | 06:41 PM
Blurry94's Avatar
Blurry94
Been busy blasting and painting parts too.
Old May 14, 2026 | 06:56 PM
Blurry94's Avatar
Blurry94
A few more pieces...
Blurry94's Avatar
Blurry94
I ended up braking one of the brake lines due to rust. So now they're all getting R&R'd.
Old May 16, 2026 | 11:28 PM
Blurry94's Avatar
Blurry94
Got the heads back and gave them a few coats of paint. Now I'm trying to decide on which valve cover to go with.
Old May 16, 2026 | 11:31 PM
Blurry94's Avatar
Blurry94
Here are the headers..
Old May 18, 2026 | 05:24 AM
torq'ta 5 8's Avatar
torq'ta 5 8
sure are purdy and blue now that you worked on'em.
Old May 18, 2026 | 06:47 AM
manicmechanic007's Avatar
manicmechanic007
Unless you have a stud girdle
I sure would use the prretty blue factory ones, now that you made them look so nice
Old May 18, 2026 | 05:04 PM
Blurry94's Avatar
Blurry94
Does anyone make aftermarket plastic front inner fender liners. The ones I have are very brittle and falling apart.
I'm not seeing anything on the normal goto sites or flea-bay.
Old May 18, 2026 | 06:51 PM
cwegga's Avatar
cwegga
JBG appears to have some. https://shop.broncograveyard.com/78-...tinfo/24035PR/
Old May 18, 2026 | 08:25 PM
  #28
Blurry94's Avatar
Blurry94
And in stock...thanks!
Old Jun 1, 2026 | 07:12 PM
  #29
Blurry94's Avatar
Blurry94
I have decided to go with a retro hydraulic roller cam and lifters. Question I have is about the factory rocker arm ratio, are they 1.73:1?
Old Jun 2, 2026 | 08:23 AM
  #30
manicmechanic007
Yes, factory ratio of a Cleveland rocker arm is 1.73 :1
You realize with a roller cam you will need to shave the pedestals and install screw in studs and a guide plate like a Boss 351 head has?
Put bronze guides in it at the same time (your 47 year old guides are probably worn out pretty good by now)
Those motors were a bit hard on guides anyway, especially when you put a decent cam in one
Enjoy that 79, last of the good ole straight axle ones, and the beat one of them IMO
Yours is one I would rid myself of most of the smog, maybe keep it on there, and just block off the EGR with a plate under the valve and leave the EGR carb spacer there
