No more interior clip problems
One of the most annoying things I have found with the newer Ford's has been in inability to disassemble interior parts without damaging them. Older Ford trucks used steel clips and the new trucks use plastic. The orange clips specifically seem to be the worst for removal because the shape of them lends itself to becoming "hooked" on the plastic is it clipped into and when you try to pull them apart, a lot of the time the tab on the back of the panel ends up being the weak link.
I have since picked up a box of steel clips, and after using them for a while, I have noticed the panels no longer feel like you are going to break something when pulling apart.
I wish Ford could pass these cost savings down to the owners, but I guess most of their customers will never notice. Hopefully this can be of some help to the forum members here....or at least make working on interiors a little easy....no more plastic welding
25281
(Ford: W716909-S439)
Silver Magni-565
Interior Trim Panel Fastener
Width: 15mm
Length: 19.5mm
'U Width: 10mm
Ford Expedition 2018 - On, FI50 2015 - On, F250 & F350 2017 - On, Mustang 2021 - On;
Lincoln Navigator 2018 - On
UNIT PACKAGE: 50
On another note my son built out a contractor van last spring and added a Thunderbolt lock system. When we took the trim panels off all 5 doors we used the trim removal tool. That being said some of the plastic clips were so buried in the sheet metal inners the metal (thin) actually deformed in a few spots. None of the clips broke but some of the embossed metal pads on the inner panels were not flat any more.
