Road draft conversion on 1992 4.9L??
Old Feb 27, 2026 | 10:30 PM
Tracy_N42's Avatar
Tracy_N42
4th Gear
I can post pics tomorrow. but im really curious as to what happened to my emissions system on my 1992 f150 4.9l. factory it came with the smog pump and egr. i bought the truck as it is now, i am not the one who did this to it. I'm also in a non inspection state and this is kinda just a project vehicle for me so I'm not super worried about getting it back to totally stock, but you'll see why I'm a little concerned if you read lol.
from what i can tell it looks like it's been road draft "converted"? being 1992 its way too new to have a road draft tube.... but theres a little slash cut tube just dumping onto the ground next to the transmission that looks like it's attached to a rubber hose coming out somewhere up by the valve cover/exhaust. the smog pump is still there but the hoses are gone and theres a different belt that doesn't go around it. did someone convert this from egr/smog pump to a road draft system or is the road draft tube part of the factory system? TIA
Old Feb 27, 2026 | 11:40 PM
HydroDog's Avatar
HydroDog
My 1965 didn’t even come with a road draft tube.
Is there not an emission sticker on the underside of the hood showing hose routing? You should have a PVC valve in the top of the valve cover with at a minimum of a hose from that to the intake manifold.
Old Feb 28, 2026 | 08:39 AM
Hit Man X's Avatar
Hit Man X
Valve cover has two ports, rear is the PCV supply to plenum and front runs to the air filter box with a tiny filter within.
Still have an O2 sensor? Leave the TAB and TAD electrically plugged in if still there, as well as the EGR position sensor, even if no vac lines to them. Keeps codes to a minimum.
Snap pics if you have time
Old Feb 28, 2026 | 08:45 AM
KULTULZ's Avatar
KULTULZ
If the engine has a compromised PCV SYSTEM, it will affect the longevity of the engine.
The crankcase has to be vented and road draft is not the correct way.
Old Mar 2, 2026 | 01:04 AM
manicmechanic007's Avatar
manicmechanic007
Post pictures
williape
Apr 22, 2025 07:16 AM
ssanto
Jun 6, 2006 10:24 AM
treading
Mar 22, 2006 03:55 PM
mike demos
Jun 1, 2005 02:12 PM
jims89bronco
1978 - 1996 Big Bronco
Apr 23, 2003 10:52 PM
