Ordering gas or buying diesel off the lot?
Old Mar 1, 2026 | 10:25 AM
  #31
09FX-4's Avatar
09FX-4
Originally Posted by nova801428
Hey everyone,
Would you guys considering jumping up to a 6.7 or staying with a 7.3?
Thanks!
6.7L for sure. You should still be able to use remote start from the app, so no need for the fob.
Old Mar 1, 2026 | 11:26 AM
  #32
Leardriver's Avatar
Leardriver
You aren't throwing away $4K. You will get way more for that vehicle when you sell it, and diesels have a 100K powertrain warranty. If you need big towing power, consider it.
Old Mar 1, 2026 | 03:45 PM
  #33
Rwhjr's Avatar
Rwhjr
Me personally for that difference I’d get the diesel.
Old Mar 1, 2026 | 05:30 PM
  #34
TheCyborgSlayer's Avatar
TheCyborgSlayer
I’d argue to get the 6.7 whether you need big towing power or not. Too many seem stuck in the mindset of ‘well, if you aren’t towing 40k pounds, just get the gas’.
Most purchases are primarily driven by want, not need. Did I need a diesel, no. Did I want a diesel, yes. Coming from big rigs, I love the way a diesel drives. Love the smoothness, the way it puts power down, not to mention the efficiency. I had that mindset and initially settled on a 2023 5.0 F150 Tremor, while the Tremor was great and I loved it, even after a year I was never able to shake the feeling of ‘this isn’t what I REALLY wanted’.
So my advice is always get what you want. Don’t let the ‘do I need this’ steer you. You’ll ultimately regret it.
Old Mar 1, 2026 | 05:34 PM
  #35
twobelugas's Avatar
twobelugas
I've looked pretty extensively every day and the closest thing I can find 6.5hrs away with less options than I want. There are a lot of trucks out there but they typically have a lot of options I have no desire to pay for like 5th wheel prep, XL driver assist, power sliding rear window, FX4 package, and 360 degree camera. I can bump up to an XLT without premium package and get exactly what I want tomorrow except I would like LED headlights.
Well if that's the case then might as well get the 6.7, 64.5k isn't bad this day and age for an XLT PSD with long bed.
Old Mar 1, 2026 | 06:35 PM
  #36
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
With the capability of the big gassers today, I wouldn’t put up with the headaches of a modern diesel. It’s a roll of the dice every startup between the emissions and the CP4
Old Mar 1, 2026 | 06:58 PM
  #37
nova801428's Avatar
nova801428
It's $64.5 for an STX. About 12% off including the $1k incentive.
Old Mar 1, 2026 | 07:02 PM
  #38
nova801428's Avatar
nova801428
Originally Posted by TheCyborgSlayer
ISo my advice is always get what you want. Don’t let the ‘do I need this’ steer you. You’ll ultimately regret it.
Thanks! I don't tow heavy enough to "need" a diesel it's purely a want. Like I said I'm happy with my 7.3.
Old Mar 1, 2026 | 07:04 PM
  #39
nova801428's Avatar
nova801428
That's my worry but I wonder how much is actually blown out of proportion like cam/lifters in 7.3s.
Old Mar 1, 2026 | 07:33 PM
  #40
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
The early 7.3 issues were addressed by Ford. The CP4 and emissions on the diesel can't be. Now sure, you may not have any issues at all, or it could grenade on you on your first trip. My last diesel left me stranded with only 8k miles on the odo, so I have a bit of a personal gripe with modern diesels.
Old Mar 1, 2026 | 08:05 PM
  #41
Rwhjr's Avatar
Rwhjr
You don’t say.
Old Mar 1, 2026 | 08:12 PM
  #42
ATC Crazy's Avatar
ATC Crazy
Top Answer: 10
Originally Posted by Rwhjr
You don’t say.
Kinda like you with any gas powered SD.
Old Mar 1, 2026 | 10:41 PM
  #43
seijirou's Avatar
seijirou
I've seen this written a few times but I haven't seen any source. Do you know in what way the issues were addressed and what the source is?
Old Mar 1, 2026 | 11:41 PM
  #44
chadstickpoindexter's Avatar
chadstickpoindexter
As to the diesel, they started using CP4’s with pinned buckets in 2020 so that has helped with the CP4 problem to some degree. Of course it can still detonate though, but a DPK is an inexpensive and fairly easy part to add that will protect the rest of your fuel system should it fail, which brings the repair costs down to simply a new pump.
Ford also started using a 9th injector for regens starting in 2023 also, which was definitely an improvement.
But today, no new vehicle is without some sort of concern, even the 7.3.
I am one that didn’t “need” the diesel but I sure wanted it because we do tow our camper a decent bit… cross country and into the mountains. The diesel does it so well… up and down the mountains. And as a bonus to me, it does it at lower RPM’s. I don’t want to hear it screaming, even if it is “ok.” It’s also better in fuel efficiency and being able to use the big rig pumps, especially while towing is so much nicer than trying to get through the pumps at the front with all the others.
I’m not telling you to get the diesel or the gas, but I am telling you that no matter which one you choose you can choose to worry about it or you can enjoy it. I will say though, get what you want… even if that means ordering one. It’s so nice getting exactly what you want rather than settling for what’s available.
Good luck with your choice!
Old Mar 1, 2026 | 11:53 PM
  #45
nova801428's Avatar
nova801428
Thank you! I think I will be happy with either choice I make.
