Intermittent starting issues
Old Feb 23, 2026 | 07:48 PM
Maarty's Avatar
Maarty
1st Gear
Hey All - I have been having a weird starting issue with my 2019 Ford F150 XLT 5.0.
Truck will start up just fine, even after sitting for a few days, but after short drive [5-10 min] If I turn the truck off and try to start it a few min later, it cranks slow as if the battery is low.
If I wait for 10-20 minutes, the truck will start back up just fine and crank over just fine when I get home and then not have any issues for a while.
Have noticed I'm always waiting in the cold, so that does seem to be a common trend when I have issues [25F or below].
Battery is original so 6-7 years old.
Realizing that should be my first go to, but seems weird since it starts fine when this happens, so with a junk battery I would almost expect it to do this when I first start it.
Anyone have any experience with this?
Thanks!
Old Feb 23, 2026 | 09:32 PM
F250Moneypit's Avatar
F250Moneypit
There was thread on this a few years ago, most of the problems were happening when they were towing but some of them were with the truck alone. I fixed my slow cranking problem with a new starter.
https://www.ford-trucks.com/forums/1...le-towing.html
Old Feb 24, 2026 | 10:54 AM
GlueGuy's Avatar
GlueGuy
+1
That is a sometimes symptom of a starter getting creaky when it gets heated up. That is the first place I would look.
Old Feb 24, 2026 | 11:59 AM
SpencerPJ's Avatar
SpencerPJ
I agree, sounds like starter, but honestly, I'd start with the battery, it is time. Mine of 6 years almost to the day, has finally shown enough signs that I bought one today.
Old Feb 24, 2026 | 02:46 PM
seventyseven250's Avatar
seventyseven250
It wouldn't be out of line to replace this battery without any further diagnosis, BUT, if you wanted you could mess around with battery chargers and voltage testers etc and see what you find. I actually really like those voltage displays that plug into your cigarette lighter. You can get a good idea of voltage before you start, while driving, and a dozen times a day if you want. Could help you find some pattern to the situation that isn't obvious from teh symptoms so far.
My bet is starter.
Old Feb 24, 2026 | 05:24 PM
2017coyote's Avatar
2017coyote
Change the battery for PM maintenance and cheap insurance for when it does die.
After that see if your starting woes go away.
Old Feb 24, 2026 | 07:29 PM
SMSTX's Avatar
SMSTX
5.0's heat soak the starter. After so many heat cycles it does exactly what your experiencing. We replace about 1 a week
fordman19762003
6.2L V8
Jun 9, 2020 06:08 AM
mark227
Dec 16, 2016 12:17 PM
DyceDesign
Dec 2, 2009 12:10 PM
ajeffrey
Feb 6, 2008 09:11 AM
Dilligas
15
Feb 4, 2008 07:41 AM
