Incorrect speedometer
Old Feb 22, 2026 | 09:30 AM
MintChocolateChipIdi's Avatar
4wd Low
Hello everyone!
I’ve been having a strange speedometer problem on my 86. After about 65mph the speed goes up much fast than your actual speed. It is accurate until then according to gps. But 70 mph reads as 80mph and so on. Any good fixes? Thanks!
Old Feb 22, 2026 | 09:54 AM
FuzzFace2's Avatar
FuzzFace2
Was anything done before this happened? Cluster pulled to replace bulbs maybe? Paint the needles?
If I had to guess it would be a gummed up cable or the needle bearing on the gauge it's self.
I think more the needle bearing at the gauge.
IIRC there is a magnet that passes a magnet on the needle that pulls the needle till it goes to far and it drops back down.
Because the needle does not have time to get back to zero before the magnet comes by it pulls it back up and starts all over again.
Now why it would read faster after 70 is beyond me
Dave ----
Old Feb 24, 2026 | 12:09 PM
4wd Low
Great Info!
To my knowledge this cluster has never been out of the truck.
Is there any way I can safely rebuild it? Or even gain access to this needle bearing to grease it? I can't find any parts or any sources for a rebuilder.
Thanks
Old Feb 24, 2026 | 01:08 PM
Franklin2's Avatar
Franklin2
You can take it apart and spray some wd40 around in it. Usually fixes it for me.
Old Feb 24, 2026 | 01:46 PM
FuzzFace2's Avatar
FuzzFace2
When you take it apart if you have a auto be vary careful of the string for the gear selector needle.
I think once you get the gauge cluster out and take it apart you will see how the speedo needle works.
It will also be a good time to replace all the bulbs.
Dave ----
Moongypsy
Dec 30, 2022 09:46 PM
MrGGermany
Jul 16, 2022 04:07 PM
995.4SD
Nov 1, 2011 09:43 PM
wtrlogd
6.7L Power Stroke Diesel
Jul 30, 2011 05:58 PM
Hammy211
General Automotive Discussion
17
Mar 14, 2004 05:55 PM
