Sponsored by: Real Truck
cab clearance lights
Old Feb 22, 2026 | 09:22 AM
Ken Hunsucker's Avatar
Ken Hunsucker
6th Gear
Lightbulb cab clearance lights
Just an fyi, I had an issue with the clearance lights on my 2011 F350 Lariat, they all went out at the same time. Naturally I thought it was a fuse, since it was all at once. So, I started checking all the fuses, all were good (SMH). Started checking each individual blub and couldn't tell which one was blown.
So long story longer I ended up replacing all of them at once and to my surprise (BLING) lights are all back on.
Does anyone know for sure if these clearance lights are wired in series, like the old Xmas lights, seems like at least in my case that they were, one light goes out and they all go out. Anyway, problem fixed, hope this helps save some time for someone else if they come across this issue, it may not be a fuse.
Old Feb 22, 2026 | 11:11 AM
Pikachu's Avatar
Pikachu
They aren't wired in series. The body control module might have interpreted something as shorted and killed the output to the circuit.
Old Feb 23, 2026 | 08:44 AM
Ken Hunsucker
6th Gear
Smile Clearence Lights
Thanks for the info, so far so good, all's working well/
Rvnwlf
May 19, 2023 07:27 AM
Will1997f350cclbdually
Sep 6, 2022 12:50 PM
Lockholder
62
Feb 23, 2022 05:16 PM
lebanontn
May 14, 2011 08:40 AM
Glockem45
Jan 12, 2006 04:18 AM
