Sponsored by: Real Truck
Interior courtesy lights not working, please help.
Old Dec 31, 2005 | 09:04 AM
Glockem45's Avatar
Glockem45
Question Interior courtesy lights not working, please help.
All the lights work inside the truck fine, but the lights next to the dome lights don't work. These are the lights that you actually have to hit the selector switch to make the smaller lights turn on so you can read a book or whatever. I looked through the fuse chart and there doesn't seem to be a dedicated fuse to these three sets of lights on the ceiling. What or where else do I need to look for the answer?
Old Dec 31, 2005 | 01:36 PM
estimator's Avatar
estimator
Could it be something silly like a burnt out blub?
Old Dec 31, 2005 | 01:55 PM
ryaneverk2's Avatar
ryaneverk2
Check the bulb first. Are both out? Or all 4 if it's a cre cab? Probably a fuse then. The charts in the owners manual can name things a little funny sometimes, I've found... so just look at the fuses under the dash to see if you see any that are blown, and then see what they call them in the manual. That's what I'd do.
Old Dec 31, 2005 | 02:05 PM
dmp437's Avatar
dmp437
Check Fuse #4 listed at 10 amps. It powers the map lights, front & rear, the glove compartment lamp, the engine compartment lamp, and the vanity mirror lamps in the visors. The dome lights and other lights that work when the doors open are on Fuse #14, also a 10 amp.
Old Dec 31, 2005 | 04:16 PM
Glockem45's Avatar
Glockem45
All four bulbs are good. The dome lights work, the hood light works, the sun visor lights work. Everything else seems to work fine, but the darn switch lights overhead. I will check fuse #4 and #14 as suggested, but since everything else is working fine, I assume both of these fuses are still working, right?
Old Jan 2, 2006 | 04:28 AM
dmp437's Avatar
dmp437
If the rest of the bulbs on that circuit work then the fuses are probably good. Which leaves you a pinched or loose wire or a bad ground, and I don't thnk it's the ground.
Old Jan 11, 2006 | 08:12 PM
lovemy01f250's Avatar
lovemy01f250
Anyone know where I can get a complete fuse box diagram? Bought my 01 f250 used from a dealer without an owner's manual, and have several electrical issues.
Old Jan 12, 2006 | 04:18 AM
dmp437's Avatar
dmp437
Haynes has a "service manual" that has a set of electical diagrams in the back of it. AutoZone and stores like it sell it for $17 or so, E-Bay usually has them for $11 + shipping.
jmac7
2004 - 2008 F150
Sep 24, 2018 04:02 PM
Pat_
Nov 4, 2017 07:24 PM
Onus
46
Jan 5, 2016 08:38 PM
MasonGeneral
Nov 4, 2012 06:25 AM
Gd71eb
16
Jan 11, 2012 08:50 AM
