No engine warning lights
Old May 18, 2023 | 05:54 AM
Rvnwlf's Avatar
Rvnwlf
1st Gear
Morning,
I can't seem to find any info on my specific problem.
My 2001 f350 7.3 is completely stock (except for the radio). The issue I'm having is this.
Everything is working except for the idiot lights on the dash. All interior lights, head/tail lights, running lights, dash illumination lights, gas peddle are/is working. Is there a fuse specific to those lights? I'm just looking for some thoughts before tearing into it to check wiring.
Any thoughts or suggestions would be appreciated.
Thank you,
Kurt F
Old May 18, 2023 | 10:25 PM
kbeefy's Avatar
kbeefy
Does it start and run?
Do the lights prove out (illuminate) when you initially turn the key to the run position?
Old May 18, 2023 | 10:36 PM
kbeefy's Avatar
kbeefy
Fuse # 15, 19 & 29.
Charge and airbag lights are on Fuse # 29, almost all the remaining lights are on fuse # 19.
Old May 19, 2023 | 07:27 AM
Sous's Avatar
Sous
FTE Leadership Emeritus
FTE Emeritus
Kurt, I'm not sure about your 2001, but on my 2000 there are ribbon cable style contacts on the back of the instrument cluster. You can clean them with a pencil eraser and some contact cleaner to see if that helps. I learned that trick many years ago and have used it on a few occasions including fixing the electrical panel on our LG range.
At 22 years old, I am hopeful you have an easy fix.
Further than what has been suggested, you may need to look into FORScan or FORScan Lite to see if there are any codes lingering.
Melvin86
Jan 24, 2022 08:08 PM
Digger196
Dec 27, 2021 11:45 AM
PowerStrokeJustice99
Jun 1, 2019 01:54 PM
skip hatfield
2004 - 2008 F150
Mar 17, 2010 02:02 AM
