54 build
Old Feb 19, 2026 | 03:05 AM
northfork's Avatar
northfork
Trailering
54 build
I posted a while back about advice for this build and have finally started. It’s going to be a slow process but I’ve got the truck torn down for the most part. Mustang II IFS and explorer 8.8 with TCI 4 link for the rear. Chassis work has begun.
I need to start boxing the frame. I’ve got a bunch of leftover 1/4” plate to use but was a bit surprised how thin and light the factory frame is. Any reason to not use 1/4” other than weight? I’m thinking of boxing basically the whole front and mid section basically from the radiator support to the rear crossmember where the 4 link brackets attach. Seems like a lot of plates I see for sale are only 1/8”.
The TCI 4 link lowers the rear about 4”, does this generally require c notching? Everything is going to get mocked up but good to have a plan going forward.
Old Feb 19, 2026 | 07:19 AM
PLM1955's Avatar
PLM1955
You are doing pretty much what I did. I used 3/16 inch I believe for the boxing plates, but it could be 1/4 inch. I went all the way to the cross member bar that supports the coilover shocks, with just a small gap between the two. I'm pleased with the results. Something I failed to consider when I boxed my frame rails, was those items, such as the running board mounts, battery box, etc., that were held on with a bolts and nuts, were now going to be a problem. I solved it by drilling the original holes all the way through the backing plates. I believe if I had it to do again, I would have welded nuts on the inside of the frame, before I boxed them.
As for the notching the frame rails, I haven't done that yet. I'm hoping I can get away with avoiding that. We'll see if that's going to be possible.
Old Feb 19, 2026 | 10:28 AM
northfork's Avatar
northfork
Trailering
Cool. Did you leave the crossmember that the 4 link brackets attach too and just box on both sides, front and rear?
Good thought on the running board nuts.
Old Feb 19, 2026 | 12:08 PM
M2HB's Avatar
M2HB
The factory frame is .150 inches thick. It is light. I used 3/16 plate (.188) cold rolled steel, to box my frame. I also made a 3/16 channel within the original channel. It is way over doing the frame, but it is very strong.
Old Feb 19, 2026 | 06:10 PM
Marten's Avatar
Marten
I used 1/8" plate to box my frame. Key is making sure the frame is straight, square, etc. and then well braced so it doesn't change when welding. I also added a 1/4" nut every 12" on the inside of the boxing plates and drilled a hole through the plate. That gives me lots of places to put small bolts to hold stuff, wiring, hoses etc. And I am running 400 hp and it holds up well.
Old Feb 19, 2026 | 06:57 PM
northfork's Avatar
northfork
Trailering
Good ideas, thanks.
I should probably blast the frame before I box it to remove the rust/paint. Any input on coatings for the inside of the boxed sections? I’m not really keen on powder coating the frame as it renders modification or repair difficult.
Old Feb 19, 2026 | 07:49 PM
52 Merc's Avatar
52 Merc
Before you box it I'd highly recommend you check and measure the frame for twist, diamond and square. Once boxed, if it's not within spec, there's no fixing it.
Old Feb 19, 2026 | 08:00 PM
northfork's Avatar
northfork
Trailering
Awesome idea, it was on my mind but good to hear. I was going to use 4 adjustable stands to get everything level and plumb. Hopefully it’s square so I don’t have to mess too much with that. These frames flex like crazy in stock form, I can only image how much they sway taking a corner.
Old Feb 19, 2026 | 08:32 PM
52 Merc's Avatar
52 Merc
You can check for square by cross measuring from given points side to side and compare the measurements. Ideally you'll be within 1/16" on any measurement under 100". Over 100" you can have 1/8" fudge factor.
This is not a truck frame or the measurements you're looking for, just an example of how it's done, in case you or someone else reading didn't know. Pick the same points on each side and measure for comparison.
Old Feb 19, 2026 | 08:47 PM
M2HB's Avatar
M2HB
https://www.ford-trucks.com/forums/1...-restomod.html
On my build thread, I covered how I rebuilt and reinforced my factory frame.
I probably went overboard, but it is real strong.
I welded in over 100 flange nuts to the inside of the frame, before I boxed it. I could have used a few more.
Old Feb 19, 2026 | 09:06 PM
northfork's Avatar
northfork
Trailering
Holy smokes, that’s like an up armored version! I’m definitely not going to have the time and resources to get that involved, but looks sweet.
Old Feb 20, 2026 | 09:44 PM
PLM1955's Avatar
PLM1955
I removed that crossmember and once I finished boxing the frame, I welded it back in place, with some modifications to make it fit.
ingo
24
Dec 16, 2024 02:50 PM
stanger66
16
Sep 3, 2023 03:40 PM
Damage truck
33
Nov 18, 2017 06:54 PM
natewatts5
Nov 14, 2015 12:11 PM
CTom
30
Aug 28, 2014 03:38 PM
