2002 Ranger won't start
Old Feb 14, 2026 | 10:51 AM
Stan02Ranger's Avatar
Stan02Ranger
I have a 2002 Ford Ranger with the 4.0 engine. It's been running great and up until a couple of weeks ago it was my daily driver. With a cold snap headed south last month, I backed it in the driveway and parked it. It had started fine and was running great. A few days later I went out to start it and go to the store but it would not crank. The battery is good and it turns over. I'm assuming it's not getting gas or a spark, but I'm no mechanic. I put a reader on it and it's not throwing any codes even when I try and start it.
Does anyone have any tips for me to try and get it running before I have it towed to a mechanic? I'd appreciate any input you may have.
Thanks,
Old Feb 14, 2026 | 11:45 AM
BareBonesXL's Avatar
BareBonesXL
Pedantic stuff - crank and turn over are the same thing.
Sounds like you're saying the engine turns over using the starter but the engine does not start and stay running. Does it make any sounds at all ike it's trying to start?
Since it's a cold weather problem the first thing that I'd try is starting fluid. That's why it was created. Any auto parts store, maybe even your local gas station or corner grocery store or even the big chains should have it.
Find a port in to the intake system after the filter and squirt a big shot in. If you have spark it should start. It might not stay running though if you don't have injection or fuel.
If the weather warms up you might try it again before having it towed.
p.s. I've also read, but not experienced, that cold can cuase a weak fuel pump to lock up. The fix is to bang on the fuel tank to break it loose.
Old Feb 14, 2026 | 12:57 PM
Stan02Ranger
The weather has warmed up and I'm still having the same issue. I'll go try and bang on the fuel tank a few times.
You are correct, the starter is turning but no sounds of ignition. I'll give the starter fluid a try too.
Thanks
Old Feb 15, 2026 | 04:41 PM
Lepidopterodactyl's Avatar
Lepidopterodactyl
Are you still on the original ignition coil pack? That's usually a pretty easy and cheap repair. The coil on my Duratec just went last spring - spent an hour putting that in plus plugs and plug wires for good measure. Cost me less than $100 including a set of spark plug sockets.
Also, when you turn the key to "run (not start)," you should hear the fuel pump run for a few seconds. If you can't, that can be the culprit
Old Mar 1, 2026 | 01:58 PM
Stan02Ranger
The weather warmed up, the ground dried up, and I went out and tapped the area under the fuel pump with a piece of wood a few times. Cranked right up.
Thanks for the help.
fordranger94
Nov 12, 2019 10:51 AM
Flipcarroll
4 Cylinder Engines
Jan 27, 2017 03:08 PM
Mike1998Ranger
Electrical Systems/Wiring
Sep 13, 2013 07:41 PM
user 2833083
Aug 1, 2005 08:36 PM
1sunny1
May 3, 2002 09:04 PM
