Chasing Vibrations
Old Feb 24, 2026 | 05:40 AM
Freedom-over-safety's Avatar
Freedom-over-safety
Originally Posted by unleashd
Visual inspection, no slop/play when turning them by hand. Yes, I can replace them to remove a variable, but holding off on simply throwing parts at it without proper diagnosis.
yeah a lot of the time they’ll be dry and still feel good just turning by hand. Pull the driveshaft and pull the caps off the open ends of the u joints. Easy and quick way to see if they’re dry.
Does yours have a carrier bearing? That could be going bad as well.
I had a vibration that I chased for quite a while, and I accidentally fixed it when i upgraded to a manual transfer case. The original transfer case had a bearing going bad that caused the vibration.
Old Feb 24, 2026 | 06:25 AM
unleashd's Avatar
unleashd
@Freedom-over-safety Thanks for the pointers. Will surely look into these. I don't have a carrier bearing, so that is one less variable.
Old Feb 25, 2026 | 05:59 AM
Freedom-over-safety
Yeah i haven’t figured out why some have a carrier bearing and some don’t. They’re all the same wheelbase so it doesn’t make sense.
Good luck, post up what you find.
Old Feb 26, 2026 | 07:21 PM
unleashd's Avatar
unleashd
Happy to report that the vibrations are now gone
In the process of diagnosing and fixing the issue, a number of things were replaced. Almost every moving part in the front end is now new. I know that some of will have to be categorized as "throwing parts ($$$) at the problem". I opted to do that since most of the front end was disassembled to diagnose the vibration problem and the hope that I do not have to be doing these fixes somewhere on the road.
  • All new Spicer U-Joints for knuckles (1 of them had damage)
  • All new Spicer U-Joints for front & rear driveshafts replaced as preventive maintenance
  • All 4 ball joints replaced with Mevotech. Passenger upper ball joint had too much play. Rest were replaced as preventive maintenance
  • All new Mevotech tie rod assemblies - left/right, inner/outer - replaced as preventive maintenance
  • New Warn Hubs. Driver side hub was broken.
  • New dual steering stabilizer setup from Rough Country replacing the same part. Replaced as preventive maintenance
Old Feb 27, 2026 | 06:13 AM
Freedom-over-safety
i’d say it was smart replacing all that since you were already in there and the truck is 20+ years old. Might as well set a good baseline with new parts so you can depend on it. I bet it was those rear u joints causing it.
Addison86
7.3L / 6.8L V8 Gasoline Engines
Aug 2, 2024 10:59 PM
GM in a Ford
Mar 5, 2024 09:11 AM
cmcolfax
Jul 21, 2018 04:02 PM
Maverick68F100
20
Jun 29, 2016 11:36 AM
JaySVX
Feb 26, 2008 02:38 PM
