Adjustable Conventional Hitch
Old Feb 13, 2026 | 10:39 AM
sicdrummer27's Avatar
sicdrummer27
I have always used standard conventional hitches with a welded drop. And have a few for different heights.
Thinking of getting adjustable one where I can adjust height and also flip the ball between 2 5/16 and 2".
Was looking at a Curt one but anyone have any recommendations? This will be for a 350 with the 2.5" receiver. Do know if these have play due to the ball adjustment pins and create any noise of you feel any sort of movement towing.
Old Feb 13, 2026 | 11:54 AM
Phillbo's Avatar
Phillbo
They all have a little slop in the shaft/pin. I have an anti rattle u bolt / plate device I use on mine and it gets rid of all the slop.
https://www.harborfreight.com/anti-r...BoCvMwQAvD_BwE
Old Feb 13, 2026 | 11:59 AM
longhaultransport's Avatar
longhaultransport
For short trips I use an adjustable aluminum hitch.
For long distance or high speed I use forged drop hitches for my needs. I keep different size *****, impact gun and socket on board for changing the ball size as needed.
I like these Forged Ball Mounts
Old Feb 13, 2026 | 12:01 PM
99powerstrokedF250's Avatar
99powerstrokedF250
Whether you use an adapter or a 2.5" shank, you'll have some rattle until you get some road grime built up in there. Personally it's far enough away that I never notice it when I'm driving.
I have a B&W Tow & Stow. I like it, but you've got to keep the pins greased (I usually do it in the spring and fall). It is rock-solid.
Old Feb 14, 2026 | 10:17 PM
HRTKD's Avatar
HRTKD
I use a 3" shank Weigh Safe adjustable height that has interchangeable 2" and 2 5/16" *****. It works great for my 3" receiver. I didn't want to use any reducer sleeves. The built-in tongue scale is handy at times to see what the tongue weight really is.
Old Feb 15, 2026 | 06:56 AM
sicdrummer27
I heard the built in scale gets water in it eventually. That your experience so far?
Old Feb 15, 2026 | 06:58 AM
sicdrummer27
I am looking at a forged one. I do have the anti-rattle piece for the hitch.
For the pins on the shank, is there typically a lot of play there?
Old Feb 15, 2026 | 08:41 AM
scraprat's Avatar
scraprat
Top Answer: 5
I've had this setup for almost 20 years now and just changed the hitch head a couple years back. A couple nice things about this setup no one wants to steal something so ugly and manual, pesky 4 bolts to adjust if needed. If a vehicle hits it its built like a tank. Reverse it either direction depending on height needed.
Down fall is it can bruise the shins pretty good if forgetting it there.
Old Feb 15, 2026 | 09:06 AM
HRTKD's Avatar
HRTKD
I haven't experienced that nor have I read any posts about that on this forum. I live in a dry climate so maybe that has something to do with it.
Old Feb 15, 2026 | 09:35 AM
kshoop1958's Avatar
kshoop1958
Originally Posted by scraprat
I've had this setup for almost 20 years now and just changed the hitch head a couple years back. A couple nice things about this setup no one wants to steal something so ugly and manual, pesky 4 bolts to adjust if needed. If a vehicle hits it its built like a tank. Reverse it either direction depending on height needed. Down fall is it can bruise the shins pretty good if forgetting it there.
Scrap, that hitch is so ugly I bet they slapped the mother when it was born!
Old Feb 15, 2026 | 10:50 AM
art cooney's Avatar
art cooney
Trailering
@sicdrummer27e got that Curt adjustable hitch. The ball part has a rubber piece that pushes up against the other part so that it puts pressure on both pins so that they don't rattle.
Old Feb 15, 2026 | 04:05 PM
sicdrummer27
Was really leaning towards the curt but max tongue weight is 2k. My one trailer will be over 1.5k on the tounge. I would like one with more buffer.
Old Feb 16, 2026 | 07:51 AM
SpencerPJ's Avatar
SpencerPJ
My friend has one, nice shiny one, sits relatively close to the receiver. The draw back to his style is, I watched him back his rPod trailer, he nearly jackknifed his trailer with so little shank extension. My conclusion is, many styles, choose wisely.
Old Feb 16, 2026 | 10:01 AM
Phillbo's Avatar
Phillbo
I have this one and get no rattle out of the ball piece. I do have to use an anti rattle at the shank because it's 2" and my reviever is 3" which means 2 adapters to size it down.
Old Feb 17, 2026 | 10:00 PM
Midwest87's Avatar
Midwest87
