Wheel Compatibility
Old Feb 11, 2026 | 10:35 PM
sgr60's Avatar
sgr60
4wd Low
Wheel Compatibility
Sorry in advance, I'm sure someone has already posted this info, but I haven't been able to find it...
I'm looking for OE-style polished aluminum wheels for my '97 F-350. I'm seeing a lot out there for sale, but I'm not sure which wheels are cross-compatible - i.e. correct bolt pattern, backspacing/offset, etc. Curious if anyone has put together a list of what works on what, or if maybe someone can tell me what specs I need to be looking for?
Thanks!
Old Feb 12, 2026 | 08:44 AM
z31freakify's Avatar
z31freakify
16x7, 8x6.5, 4.88 hub bore, as for offset according to a quick interweb search shows 5.4 offset 4.88 inset so basically a close 0 offset.
Are you looking for a stock alcoa replacement? Or something aftermarket like Alcoas or wider? Or with more offset?
Old Feb 12, 2026 | 08:46 AM
sgr60's Avatar
sgr60
4wd Low
Thanks - appreciate it! I'm ideally looking for a stock alcoa replacement, aftermarket is OK, but the stock look is what I'm after.
Old Feb 12, 2026 | 10:36 AM
Hit Man X's Avatar
Hit Man X
Single wheel are fairly easy to find, DRW? Good luck, that is a total pain in the culo...some of us have purchased entire parts trucks for them!
Old Feb 12, 2026 | 11:17 AM
z31freakify
Never crossed my mind about the nalgonas, yeah those factory alcoas will be near impossible to find, but Alcoa does make them almost identical minus the the slot for the factory hub cap clips, they do supply their brand of center caps though
scrounger
Apr 30, 2020 07:20 AM
gavin68
17
Sep 21, 2017 10:03 AM
fordf350camper
Mar 11, 2010 06:52 AM
learpilot
Sep 6, 2009 10:02 AM
NJTy180
Apr 25, 2005 02:29 PM
