The Stonemason's Truck Build-1950 F68
Old Mar 25, 2026 | 06:48 AM
Grey County Hermit's Avatar
Grey County Hermit
Thanks guys, and awesome info on the truck Wayne! Interesting about the engine swap. We are both just itching to try a test fire of that thing (will still be a bit) but in the meantime we are investigating which parts we can use. It appears to have the same transmission as ours (except with the trans style parking brake), and the rad holds water so that's a big plus. My son is really enjoying the learning curve, and I am getting continual texts like these:
While he plugs away at that stuff I am trying to sort out rear axle possibilities. His needs brakes so I have been scouring the area looking for a Dana 60 donour. So far the only one I have located is from a 73-79 series and of course it’s an oddball having come from a High Boy.
Old Mar 25, 2026 | 07:20 AM
bmoran4's Avatar
bmoran4
Parts Nerd Extraordinaire
When you get a chance, there may be some parts on that donor truck that could help other big truck fellas 'round here - things like the steering gear, brake parts, wheels and the axles.
Old Mar 25, 2026 | 08:36 PM
52 Merc's Avatar
52 Merc
If it's from a true 73-76 F250 highboy you might give that rear a second look. The highboy 4x4's kept the same narrow frame as the earlier trucks so the spring pads on the axle are still in the right place. I'm not sure if the axle is any wider, or if it is by how much. It's worth checking out if that's all you can find reasonable.
Old Mar 26, 2026 | 06:12 AM
Grey County Hermit
Wayne, I checked that axle and it has the extra overall width (wms to wms) of the 73-79 series, along with the narrower spring pad width of the 64-72 series. Installation wouldn't be too bad as a result. I'm not sure if there are any other differences in the High Boys (and it apparently came out of a true High Boy truck). We are still batting ideas around, but this axle has what I suspect would be the best all-around ratio for us (4.10). I'm kinda tempted to get it as a "just in case" thing to have on hand. These axles are quite rare up here, and the price is good. We can always sell it.
Old Mar 27, 2026 | 01:48 PM
Truckfarm's Avatar
Truckfarm
That engine and frame are a great find! Protect it from the night sky and elements, so condensation doesn't rust it! That could really set you back. I love following this project, keep up the good work and education!
Grey County Hermit
Oct 13, 2025 07:37 AM
BonelessJungleHam
23
Feb 22, 2024 10:10 AM
imabaka
48
Nov 5, 2013 09:33 PM
kelsey_kaye
81
Jul 24, 2012 03:34 PM
BishopRyan
15
May 15, 2008 08:21 AM
