BUILD THREAD: Bringing a '76 back from the dead (Pic. Heavy 56K BEWARE)
I recently purchased my grandpa's 1976 F-150 after he passed. He used it as a farm truck up until around November 2010 when the engine caught fire. Right now I'm in the process of stripping all the interior and engine bay area. On to some pics..
Picking it up from my grandma:
My friend trying to figure out where all the damn bolts were:
Most of the interior gone:
Trying to assess the damage:
Removed some of the mess in the engine bay:
Tucked away in it's new home after hours of cleaning the garage out for the year:
I know this will be a long process full of blood, sweat, and tears. All of the above have already been invested into the project so far besides the tears, but I still have faith that they will be shed at some point. Being a college student, my time is limited, but I look forward to customizing this truck to fit my style.
I see nothing wrong with your inspiration. Build it to suit YOU. You will get opinions when you ask for them (and some times even when you don't), but who cares, it's your truck.
I recently sold my 2wd 68 F-100 short box. I hated getting rid of it, but it was time, 3" drop in the front and 5" drop in the rear. It would have been a sweet ride if I had ever finished it.
Good luck on your build.
Got a bit further with the tear down this weekend.
Front clip removed:
A/C out completely. (It was a pain in the *** since all the plastic was melted around the firewall. I ended up having to kick it out.):
Dash and wiring all out:
Close up of the engine:
Next weekend I should have the motor pulled so we can see if it's even worth rebuilding or not. Other than that I've been researching for other parts like distributor, alternator, master cylinder, etc..
Front clip removed:
I need a little help from yall. I'm trying to decide what to buy ignition-wise since the motor hasn't been looked at yet and motor parts are irrelevant right now.
I saw this kit on jegs: MSD Ignition 8595K MSD Ready-To-Run Ignition Kits. It's the ready-to-run, but for the high price, I'm sure I could find something cheaper. I don't necessarily need a billet dizzy, so I'm wondering what would be a good suggestion for one. There's so many out there, and I'm just not sure what exactly I should be looking for spec wise.
Also what is HEI about? I've been reading posts, and not sure what the whole duraspark thing is about either. Hope yall can clear these two things up for me.
Lastly, would the blaster 2 coil be a good buy?
A good ignition system is usually selected based on what you expect to get out of your engine. But if the engine is stock...it's easy to go overkill with things you don't really need.
Nice truck! Welcome to FTE!
If the motor is salvageable, the most that would happen is a mild bore, bolt on performance parts, and cam. Just something to give it some more grunt, but definitely nothing extreme/overkill. My daily is a 350z so I don't need something to really have to get up and go.
Forgot to add, since everything is burned up anyway. I figured I might as well upgrade some things, but once again, nothing too extreme. Something just a bit better than stock, if actually needed.
