Sponsored by: Real Truck
stuck in drive
Old Feb 10, 2026 | 07:22 AM
mickster 101's Avatar
mickster 101
8th Gear
stuck in drive
I have a 2001 f250 4x4 V10
Truck drove fine the day before , when i stared it up the next day after a rain and then a really cold night like 12 degrees Its now stuck in drive in all positions PNRD12 ,
Could the PCM which has happened before have gotten wet and caused this issue. All the linkage and fluid is working like it sghoud.
Old Feb 10, 2026 | 09:18 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
The PCM can't override park or reverse. If the shifter is in park, the PCM can't make it move.
Your linkage isn't working, despite what you said. It can be disconnected inside the transmission. Have you checked there?
Old Feb 10, 2026 | 09:22 AM
mickster 101
8th Gear
I have not dropped the pan yet , That was my next move, I removed the linkage and shift it by have and still stuck in drive.
Old Feb 17, 2026 | 05:53 AM
mickster 101
8th Gear
So I dropped the pan and the linkage is working as it should , nothing lose or broken.
any other suggestions.
Old Feb 17, 2026 | 06:00 AM
mickster 101
8th Gear
Perhaps a cross leak in the valve body?
Old Feb 17, 2026 | 11:12 AM
Mark Kovalsky
When it is in park, will it actually roll forward, or does it just try to move forward, but park holds it?
Old Feb 17, 2026 | 03:20 PM
mickster 101
8th Gear
I will engage in park and stop the truck and not let it move but it’s still in drive and you can throttle it and feel it try to move , the only time it will not move forward is if it is in park and in reverse. If you let it roll forward in neutral and shif it in to reverse it will stop going forward like it’s in reverse but it won’t move , its like the E brake is on
Old Feb 17, 2026 | 08:23 PM
Mark Kovalsky
That's a much different symptom than you first described. What you are now describing is a forward clutch that is welded together. It's time to rebuild or replace that transmission. It's done.
travlnman
2021+ F150
Feb 20, 2025 06:59 PM
CNC
Nov 21, 2013 08:45 PM
lconn
Dec 16, 2009 11:43 AM
gh1051
Jun 25, 2007 01:27 PM
Linnie Emmons
May 27, 2003 10:46 PM
