Pictured are all items that make up a fender assembly for 48 – 50 Ford F7 and F8 trucks. This assembly is especially good for building a truck on a modern chassis because it has an overall width of 82” at the center of the wheel opening. F1 through F6 fender assemblies are often too narrow for a modern chassis. These are solid rust free steel parts that are coated with epoxy primer on the finish side and POR15 on the bottom side. The grille has the accessory Stainless steel trim. Not included is a hood which is the same used on all F1 through F8 trucks. The parts are loosely bolted together to show the complete assembly. I will disassemble it for easy transportation. I’m asking $900 for everything pictured. The assembly is available for local pickup in Green Bay, Wisconsin. Please message me if you need additional information.
