First time filter/fluid change 6R100 transmission
Old Feb 7, 2026 | 11:32 AM
Brose73's Avatar
Brose73
1st Gear
Watched videos and everything is going great but found this in the transmission pan. Want to confirm what it is and where it goes. Don't have much knowledge on transmissions.
Old Feb 7, 2026 | 11:47 AM
morehouse7's Avatar
morehouse7
Toss it, it's a plug that drops out when they put the dipstick in at the factory. Not needed anymore.
Old Feb 9, 2026 | 01:29 PM
rufushusky's Avatar
rufushusky
^^ Bingo, found the same thing in my parents 1996 Mercury Mountaineer's 4R70W when I did their ATF in 2010..... they got their money's worth out of that mercon.
Old Feb 9, 2026 | 06:58 PM
TCNashville's Avatar
TCNashville
Curious as to how much transmission fluid you put in after everything was buttoned up. My '17 just turned 80K and I'm thinking about changing mine.
Old Feb 9, 2026 | 10:07 PM
Dairyboy's Avatar
Dairyboy
Glad I saw this lol I plan on doing my transmission this spring and good to know if i find that its normal
Old Feb 10, 2026 | 08:08 AM
Mark250's Avatar
Mark250
Found something similar in my 72 F-100 many years ago. Over 100k and evidently the first fluid change.
Old Feb 10, 2026 | 08:42 AM
6.2caribou's Avatar
6.2caribou
My '17 came with a drain plug in the pan (factory). I changed fluid and filter at 60k. It took just a bit over 7 quarts. I drove the truck a bit and then (twice) did a drain and refill. It took 7 quarts each of those times.
I also bought a reusable LubeLocker gasket, only to find that the factory gasket was reusable. I could have saved those $$s.
Old Feb 10, 2026 | 09:11 AM
TCNashville
Good to know, thank you. Unfortunately I don't have a drain plug in mine so it's going to be extra messy. My plan is to replace the OEM pan with one that has a drain plug. Also, all the videos I've watched about this fluid change, the filter just drops out with the pan when the pan is removed. Did you experience this and did the new filter stay in when you installed it?
Old Feb 10, 2026 | 09:19 AM
rufushusky's Avatar
rufushusky
The Dorman pan has a drain plug on it and its pretty economical.
https://www.rockauto.com/en/moreinfo...=8546&jsn=1292
I have one on my 6R140 on my 2019. Has held up ok, I am getting a little rust on the surface and the dorman drain plug rusted on me. Granted my truck is my daily, plow truck and I work for a Salt distributor so mine gets more corrosive exposure than most. I replaced the drain plug with a stainless steel one with a magnet on it when I last did my ATF in the fall. If you get one I would recommend a coat or two of paint just as insurance.
My filter didn't fall out, you do want to make sure the seal comes out of the hole the filter mounts in.
Old Feb 10, 2026 | 10:58 AM
TCNashville
Thanks for the tip Rufus. I was thinking since I'm going to replace the pan on my 6R100 with one that has a drain plug, can I just drill a hole in the OEM pan to drain the fluid? Where would be a safe place to do that on the pan? Assuming the lowest point I can see being very careful and very slow.
Old Feb 10, 2026 | 11:03 AM
rufushusky's Avatar
rufushusky
When I swapped mine out, I took out all the bolts and left the front two to let the pain splash down into the 15 quart catch pan I have had forever. Then I just zipped the last two bolts off and carefully lowered the pan with ATF in it. Didn't make too much of a mess. A broken down cardboard box helps as a backup catch all.
Old Feb 10, 2026 | 12:47 PM
morehouse7's Avatar
morehouse7
6R100 filter falls out and takes a little skill to get it back while lining up the pan at the same time, it doesn't stay in by itself. The 6R140 filter is fastened in place and doesn't drop. My pan has a drain plug from the factory, got lucky I guess..
Old Feb 11, 2026 | 11:20 AM
6.2caribou's Avatar
6.2caribou
Yes, the filter does just drop out. As Morehouse said, it can be a bit of a PITA to get it to stay up in place.
Old Feb 12, 2026 | 05:24 AM
B-ManFX4's Avatar
B-ManFX4
I drilled mine to avoid the mess. It's a 6R140 but the principal is the same. Here's a thread with pictures and suggestions to keep it less messy. https://www.ford-trucks.com/forums/1...ssion-pan.html
Pbergmann
Jan 12, 2026 09:56 PM
DieselVol
Jan 22, 2022 06:06 PM
Klemhineycutt
Oct 28, 2018 10:27 PM
LRSTony
Feb 21, 2014 01:18 PM
Northern
1997 - 2003 F150
Jul 29, 2007 10:32 PM
