76 Highboy brake bleeding issue
Just replaced my front calipers on my 76 highboy and I cannot seem to get the air bled outta the lines now.
i did fumble around a bit getting the drivers side line back on so likely got quite a bit of air in the line, and I didn’t gravity bleed them before I got to pumpin (rookie mistake).
Besides that and to the best of my knowledge, I’ve done the procedure properly. started back right, back left, no air. Fronts however, absolutely insane amount of air that never seems to end! I’ve gone through 3 quarts of brake fluid and still a **** ton of air coming out when I crack the bleeder on both sides.
I’ve got no fluid leaks that I can see and I’ve been diligent with keeping the master cylinder topped up.
How much air is normal and how much fluid should I expect to go through to get these brakes bled out? Something seems off. Had no air problems prior to changing these calipers.
Any thoughts? Just keep goin?
I started out solo, ran a clear tube on the bleeders with a zip tie to keep it tight. Ran a loop up (to stop air from sucking back in) and then down into a plastic bottle to catch the old fluid. Crack the bleeder and pump the brakes. On the last pump I would prop the pedal down with a board then close off the bleeder.
After not succeeding with this technique I had a partner to try and help buddy bleed. We ran a whole quart through with him pumping the pedal 10 times and holding while I cracked the bleeder.
lots of air coming out every time in both techniques.
one thing I did find in my research is the need to pull or push the pin on the proportioning valve, which I had not been doing. The book says on GVWR over 6900lb to push the pin in. My truck says 7700 on the door tag, but I don’t think my proportioning valve is the type you push in, rather it seems to want to be pulled out (maybe someone replaced it with the wrong one at some point?) I’ll post a pic, maybe somebody can confirm which proportioning valve is the have and if I indeed need to pull that pin?
Are you sure you're getting air ? sometimes the fluid looks like it has air but it's just from the pressure as it goes through the bleeder.. unless you're actually getting obvious air, I'd try the brakes and see if they're working properly.
The only place air can enter the system at this point is the master, and if you're keeping that full you can only bleed so much air.
How does the break pedal feel? Sometimes if the break pedal is low, it’s because the rear breaks aren’t adjusted.
I use a hand vacuum pump and I usually see bubbles because a loose connection on the vacuum hose and bleader screw, but the break pedal comes up tight.
thanks for the reply!
brake pedal is loose. I even put the wheels back on and was gonna go for a test drive but I barely had enough brake to keep me stopped when I put her in drive so I didn’t back out.
rear brakes could need adjustment, I’ll check that. But I think I have somethin else awry here. Copious amount of air
2. Make sure the master cylinder is full.
3. One person pumps the brakes until the pedal is hard and he/she holds the brake pedal down with constant force.
4. Another person opens the bleeder, starting with the one furthest from the master cylinder.
5. When the pedal is pushed to the floor, he/she keeps it to the floor until the bleeder is closed. Verbal communication helps in this step.
6. Repeat 1-5 until all air is no longer coming out of the bleeder.
7. Move to the next bleeder and repeat 1-5.
This is the way that I have always done it and it has always worked. Do not pump the pedal with the bleeder open. It will suck air back into the caliper every time. I hope it helps.
Bleeder rod hold OUT tool, make out of a piece of sheet metal. The rod does not move very much.
Before you go test driving with questionial brakes, 100% make sure the emergency/park brake works. As in it sets AND releases.
I have a '76 high boy with the same brakes as you, when I changed my calipers it took about 5 minutes to bleed them. there has to be a simple explanation, this is all I can guess.
Headloct I like that way, I need to try that so I can be a one man band bleeding brakes.
I’ll be digging into it again in the next couple days here. I’ll post back with how I make out
