Crank No start
Old Jan 29, 2026 | 03:32 PM
RigCity's Avatar
RigCity
Crank No start
Truck has been sitting for about 10 days in temps between 35-10 degrees. Batteries had enough volts to crank but not enough to fire the motor. It’s been charging for over an hour /my lack of patience keeps me trying to start it every 15 minutes. Last time the truck was at 30 for over a week it fired up nicely. Wondering if I need to swap the fuel filter or start looking at other items on the Rig. Can hear the fuel pump running before cranking.
I’ve recently done UVCH, VC harness, engine harness w GP relay, glow plugs, batteries under a year old and the truck has enough oil.
Old Jan 29, 2026 | 03:52 PM
John in OkieLand's Avatar
John in OkieLand
Battery charging in Cold Weather.
Less than many hours between charges is a useless attempt and just makes matters worse.
Cold Batteries will NOT accept a charge quickly, more like a Trickle Charge... until the battery case get warm to the touch... then it will accept many Amps of charge.
you should keep them on a Battery Tender 24/7/365 if the truck is not running down the road...
my battery volts always shows 13.3 on the Power Port DVM.
Old Jan 29, 2026 | 07:35 PM
Walleye Hunter's Avatar
Walleye Hunter
Can you plug in your block heater?
Old Jan 29, 2026 | 07:42 PM
Simclardy's Avatar
Simclardy
Yes that would help, it also reminds me that I switched from 15w40 to rotella t6 5w40. Made a huge difference. I am not a huge synthetic fan but it is thinner and that is what you want in cold weather.
Old Jan 30, 2026 | 05:41 AM
John in OkieLand
Lake Speed, "the Oil Geek" said that 5w40 full synthetic is good for year around use in diesel engines, he mentioned HEUI injectors in that video.
I have 5w40 full synthetic in my 7.3, for over a year now...
Old Jan 30, 2026 | 07:14 AM
MoBill122's Avatar
MoBill122
Papa Smurf
A high speed torque starter makes these old beast start so much faster in the cold.
Old Jan 30, 2026 | 07:21 AM
97-psd's Avatar
97-psd
So many variables impact the 7.3 on a cold start. Looks like you have many of them covered.
Which glow plug relay did you install? The factory one is less than ideal. The Stancor relay works much better.
make sure you don’t have a parasitic draw. It can really impact the truck if it sits for several days at a time.
what battery did you go with? You might consider testing them to make sure they are still good
Old Jan 30, 2026 | 09:51 AM
Brother Les's Avatar
Brother Les
Do you know that your Glow Plug Relay is even coming on, to heat up the Glow Plugs?
Buy a Volt Meter to plug into your power port and this will show you:
1) Battery voltage at rest.
2 Battery voltage with key on and "wait to start" light on. (voltage drop) GPR comes on..... If there is no voltage drop, then look into your GPR having an issue.
3) Voltage drop when trying to start. If the voltage drops TO Far (below 10.5?) the truck will not start...
4) Voltage when (if) truck starts, voltage will go up, but remember the GPR is still on (if working), even when the 'wait to start' light goes out.
5) when the GPR goes off, truck running, the voltage will rise (slowly) and settle at the point of voltage out put from the Alternator.
Have your batteries fully charged up and then have them load tested. If one of your batteries has 'issues', the 'bad' battery will pull the 'good' battery down to 'its' level.
ray040ray1
Apr 10, 2023 07:49 PM
wheelburrow
Jul 14, 2022 05:07 PM
Dlago19
May 29, 2022 06:48 PM
j250hd
Jul 11, 2011 10:16 PM
RexinReading
22
Sep 30, 2008 09:44 PM
