HEATER PLUMBING
Old Jan 28, 2026 | 02:10 PM
BDRUSSELL's Avatar
BDRUSSELL
4wd High
HEATER PLUMBING
Can anyone tell me if my heater is plumbed correctly. The top of the heater core is plumbed from the water pump connection and the bottom is from the block.
Old Jan 28, 2026 | 05:33 PM
hooler1's Avatar
hooler1
Looks correct. Normally the hot water or heat temp control valve is between the head and the bottom water inlet of the heater core. That way during the summer your heater core isnt radiating heat from the coolant from the cylinder head. But some have said and its been my experience too it doesn't seem like much of a problem.
Old Jan 28, 2026 | 06:04 PM
52 Merc's Avatar
52 Merc
Hooler is correct. The hot water flows from the head to the bottom of the heater core, where the flow pushes upward through the core taking any trapped air with it, theoretically. The upper heater core tube routes to the water pump, where it pulls the water through the heater system and recirculates the cold water back into the block, mixing with the water drawn from the bottom of the radiator. Ideally you'd want a shut off valve in the hot, lower hose to prevent that hot water circulation in the summertime, when you don't want any more heat in the cab than necessary. Even if you put the shut off in the upper, cold hose, you can still get some convection heating from the heat travelling through the water to the core. It may not be as hot, but it can still warm the cab when you don't need/want it.
Old Jan 28, 2026 | 07:40 PM
hooler1's Avatar
hooler1
Thank you Wayne!
I appreciate you describing how the heater core system works as I think its very important to the overall cooling system function.
Just my expereince but my heater never worked very well in my truck. It didn't bother me much as I usually dont have it on the road in the winter, but I still drive around a lot in the cool, even cold part of late fall. I always thought these heaters were a joke because even though I was running at 180 degrees there was little heat coming out of it. I was wondering if the core was clogged. Once I figured out that my hoses were connected wrong I changed them around, put the valve in line with the bottom inlet port, burped the cooling system with engine running from a cold start, the radiator cap off, the heater valve open, and what a difference! Now it will get almost hot in that cab, with temps in the 20's. And my engine temp is stable now at around 185*. Before it was sometimes bouncing very high probably due to air pockets.
Old Jan 28, 2026 | 08:13 PM
abe's Avatar
abe
I ought my truck in June of 1977. A week later I drove from Lancaster County to pick up my college girlfriend who lived outside philly near Norristown. We drove to Wildwood on the Jersey Shore. I couldn't figure out why my heater box was so hot. I did not know there was a shutoff valve on top of the engine to keep hot water from running through the heater. So to get away from the heat from the heater she had to sit next to me!
Old Jan 28, 2026 | 09:01 PM
hooler1's Avatar
hooler1
That's a great story Abe! 😃
Old Jan 28, 2026 | 09:38 PM
pltnsgt06's Avatar
pltnsgt06
Slick move, will try that on the misses this summer.
Doug O
Oct 2, 2025 07:25 PM
tbruz
Jan 13, 2025 11:36 AM
artscott61
20
Apr 27, 2022 10:21 AM
Old51f3
May 23, 2018 10:33 PM
sunbelt57
Dec 4, 2014 07:28 PM
