Timing Chain Replacement
Newbie/Novice mechanic here (got an experienced Ford Guy helping me).
We have a '72 390 (w/65K miles) on an engine stand that will be going into my '72 F350.
We're NOT doing a major rebuild on it, or anything like that ($).
What we are doing is:
Replacing the Stock 2 barrel with a Holley 500CFM 2 barrel.
Long Tube Headers
Getting Distributor re-curved for Low - Mid range Power (Torque) and converting the Stock Distributor to Pertronix (swapping out points).
New Plug Wires & Plugs. Nothing too crazy. Just want a solid running engine for my "new" Farm Truck.
HOWEVER......Some of the Pros on here, and other forums have warned about how the Stock Timing Chain can be worn out, and have slop in it.
I'd hate to put it back with that being the case.
I've seen where guys are installing the Double Chain set up - making it nice & tight - makes sense to me.
How difficult of a procedure is this?
I viewed some videos, and was thinking - when we yank the Distributor, we'll things set at TDC.
That would be a good time to set the new Timing Gear/Chain set in, and everything would be at TDC.
Is there a Timing Chain Set that is best/easiest to install?
What other parts (if any) would need to be replaced at the same time?
Any special tools needed?
Any advice would be appreciated.
Thanks!
The difference is how much slack there is from chain wear. My guesstimation is that with reasonable oil changes the chain should last over 200k, and not have much noticeable slop until about 100k from where you are. Of course each will have its own wear pattern that varies somewhat.
You would have to remove accessories, the front crank pulley(likely need a puller), socket to fit the crank bolt. Timing cover gasket, water pump gasket, thermostat housing gasket, a length of heater hose for the water pump to intake gap, and a timing cover crankshaft seal. I would clean the pulley seal area, and use crocus cloth to lessen the seal wear groove. I would use the seal to center the cover on the crankshaft unless you have a tool to align the cover.
tom
And since you asked.... I would also drop in new rod and crank bearings if the crank is in good shape. Also probably rings as well (after a quick dingleball hone), and perhaps an oil pump. These things are relatively cheap and it is the time do do this when the engine is out. None of this is difficult and does not require anything more "special" than a torque wrench. This would facilitate all new gaskets too, which IMHO is mandatory.
The heads are likely not setup for unleaded gas, they would not have been from the factory if truly from a '72, so that would be my biggest concern of all; the requirement of hardened exhaust valve seats. How many of those 65,000 miles were racked up on unleaded fuel? Heads would have to go to a machine shop for this. You can use a lead additive, I don't suggest it, but some do. If you don't plan to drive it much then that might be acceptable. But since you are adding headers, carb, and Pertronix (I prefer the Ford Duraspark ignition myself), at least, this suggests this is to be driven.
Good luck.
This will be a "Low Miles" Truck throughout the Spring/Summer months.
It may be driven 1K - 2K miles at most.
I ABSOLUTELY Promise that NEXT WINTER when the Farm Truck is Idle - in the Garage.....I'm definitely going to give it a complete once over.
A buddy of mine has an Automotive Machine Shop - said he'd do the heads for $500 (Hardened Seats. etc.).
The guy is a real Pro. He's been building race engines forever (mostly GM - but he does FE's, too).
Funny thing - he and I were talking awhile back - he's doing a 428CJ for a guy.
He told me that it said 352 on the block. I told him, Yeah, I knew that.
YOU GUYS ON HERE ARE THE BEST!
Thanks So Much.
I'm Learning & Getting New Ideas every day!
