2024 XLT HVAC Control Change Issue
Old Jan 23, 2026 | 02:27 PM
Donald B's Avatar
Donald B
Trailering
Hello,
I just recently added a heated Steering wheel and also an HVAC module from a 2024 that had auto climate and heated wheel, added the climate bar, but it was all mixed in with my bottom menu, My temp on the new ***** does not have a display as in 2024 they stopped coming with them, but would like to see it on the 12" screen. I was able to get a climate menu on one of the tabs where I can change the temp, but when i try and turn the driver side physical **** it does not change the temp.
Here are a few Photos
Any ideas?
d
Old Jan 26, 2026 | 09:58 AM
Donald B's Avatar
Donald B
Trailering
Anyone?
Old Mar 11, 2026 | 10:54 AM
jssierra's Avatar
jssierra
5th Gear
Did you ever get this fixed? Also would you consider doing a write up on how you swapped the heater control and added the heated steering wheel? I would like to do this to my 2024 XLT.
Thanks
Old Mar 11, 2026 | 11:00 AM
Donald B's Avatar
Donald B
Trailering
Thanks
I have a video on how it was done releasing very soon, will put it in the thread, for the harness I will let you know too. I actually have an extra heater control if interested from a 2024 SD with the HS Button.
Old Mar 11, 2026 | 12:14 PM
jssierra's Avatar
jssierra
5th Gear
Thats great, it will be very helpful. I'm also interested in the heater control. I have to do a little wiring research because I currently have heat only seats. I'm not sure the control's heated seat button will work on heat only as the seat heat pads function differently on heat/cool seats than heat only seats. Did you have a price in mind? I live in MI. Thanks
MLBajorek
2023+ Super Duty
26
Feb 12, 2026 04:45 PM
AwAfrican
2015 - 2020 F150
Jul 29, 2025 12:10 PM
Waring
1997 - 2003 F150
13
Nov 26, 2024 07:45 AM
cborgers
Sep 19, 2021 02:35 PM
frank5079
Sep 14, 2018 03:45 PM
