Hello From Georgia
Old Jan 19, 2026 | 03:17 PM
bentnail's Avatar
bentnail
8th Gear
Hello From Georgia
Just found this site after buying a used but very well kept , albeit high mileage ( 189,000) 2001 F150 Super Crew with the 4.6L engine . I'm not a mechanic by any stretch of the imagination, but I can change a part. That said, I have an ignition problem. The key will turn the engine and start the truck and even can turn it engine off, but the ignition cylinder will not turn far enough back to release the key. Thanks in advance to anyone that can offer any advice of whats going with this issue ,before I tear down the steering column to replace the actuator rod, replace the ignition cylinder, which will require a newly programmed key or an new ignition switch.
Best regards.
Old Jan 19, 2026 | 04:19 PM
charlie g's Avatar
charlie g
FTE Community Team
welcome to FTE
check the switch on the column under the dash attached to the tube,
Old Jan 19, 2026 | 05:00 PM
bentnail's Avatar
bentnail
8th Gear
Thanks for reply. What switch would that be?
Old Jan 20, 2026 | 05:53 AM
charlie g's Avatar
charlie g
FTE Community Team
the ignition switch is bolted to the tube under the dash .
Old Jan 20, 2026 | 06:42 AM
bentnail's Avatar
bentnail
8th Gear
I removed the ignition switch and started the truck with it and it cycles though run/start/off/accessories fine, nevertheless the key will not release , not even with the actuator rod manually slid forward. The ignition cylinder has to be removed, then the key can be released. Is there something I'm missing. Thanks for your help.
Best regards.
Old Jan 20, 2026 | 11:43 PM
CathedralCub's Avatar
CathedralCub
FTE Community Team
It sounds like you're on the right track, but just in case you aren't, I copied this thread over to the 1997 - 2003 F150 forum. You can find it here: https://www.ford-trucks.com/forums/1...m-georgia.html
Welcome aboard!
Old Jan 21, 2026 | 06:46 AM
bentnail's Avatar
bentnail
8th Gear
Best regards.
Old Jan 21, 2026 | 10:42 PM
CathedralCub
FTE Community Team
Best regards.
You're welcome!
It looks like you already have a response over there!
LoBall
New Member Introductions
Apr 8, 2016 01:36 AM
RaceHorse
Aug 17, 2015 09:08 PM
stryder
15
Feb 21, 2010 04:38 PM
john-h_schmidt
Jan 28, 2007 03:26 PM
