View Poll Results: Detonation Problem
Blew ceramic inner out of spark plug
0%
pinging and power loss
0%
Multiple Choice Poll. Voters: 0. You may not vote on this poll
detonation problem
Old Dec 9, 2003 | 11:10 AM
tmcoy34's Avatar
tmcoy34
detonation problem
I own a 89' F 150 with a 302 . It has around 80,000 miles.I was rescently out driving and the motor started pinging , at the same time at the same time I experianced power loss. A weird thing happened, as I was trying to drive up the last hill to make it home the pinging got so bad it blew the ceramic inner out of one of the spark plug. I am not sure what has happened . Could I have a valve train problem or what?
Old Dec 9, 2003 | 11:58 AM
TheWiz427's Avatar
TheWiz427
You do not need a poll to ask a question. It's possible the plug was weak(ceramic wise) and gave out. When was the last time you had a tune up?
Old Dec 9, 2003 | 01:03 PM
tmcoy34's Avatar
tmcoy34
I put new plugs in less than a year ago. I put a new plug in place of the failed plug and it is still pinging and is still under powered. something is wrong somewhere. Sorry about the poll , I am new to this forum and am still trying to figure it out.
Thanks
Old Dec 9, 2003 | 01:14 PM
tmcoy34's Avatar
tmcoy34
Could it be a bent push rod or a colapsed lifter or valve problem??????
Old Dec 9, 2003 | 03:17 PM
TheWiz427's Avatar
TheWiz427
If it was a bent push rod or a collasped lifter it would run rough. Check your timing! What grade gas do you use? if this problem just started you could of got some bad gas. Just a thought.
Old Dec 9, 2003 | 05:16 PM
tmcoy34's Avatar
tmcoy34
I was told that the station where I get my gas has changed to ethonal for the winter. They told me that maybe that could have stired up setement from my fuel tank and that could have plugged my fuel filter or maybe plugged an injecter. Does this sound possible for my trucks symptom.
Old Dec 9, 2003 | 05:27 PM
TheWiz427's Avatar
TheWiz427
Yes very much so!
vtjvt
Sep 27, 2015 02:32 PM
pidaster
Aug 30, 2011 06:43 PM
t4kne
May 18, 2007 09:14 AM
MPDano
15
Nov 22, 2006 06:41 PM
BigRedBronc
Computer Chips & Tuners
Aug 12, 2004 07:36 AM
