Sponsored by: Real Truck
Parasitic Draw - Electrical gurus?
Old Jan 13, 2026 | 08:34 PM
99.5_Superduty's Avatar
99.5_Superduty
I am looking at a parasitic draw. 1999.5 F350 7.3 lariat
After all the modules, etc go to sleep. I am seeing the following:
117 milliamps
Pulled all fuses inside the cab:
Fuse 1 - flasher relay 5 milliamps
Fuse 2 - PCM 2 milliamps
Fuse 15 GEM, Brake Pedal Position 8-9 milliamps. Is this normal or too much?
Then pulled all the fuses/MaxiFuses in the Power Distribution Center under the hood
Fuse 18 - Power seat 33 milliamps
Fuse 20 - Ignition Switch B4 and B5 46 milliamps
Fuse 29 - Radio 12 milliamps
Fuse 18 - I have seats from a different vehicle installed. Not sure why it is sucking so much power when not being used, but I will have to investigate.
Fuse 20 - This seems like a lot. Why is this sucking up so much power? Is it possible that various aftermarket items are wired into this circuit and sucking power? Reverse camera, Alarm system, remote start, can't think of anything else.
Fuse 29 - seems like a lot for an aftermarket radio. I believe the radio has some function where it is in standby mode for a day, then goes into a deep sleep which I assume uses less power.
If I can figure out the power seats and ignition switch I think my numbers will be in a good range.
Old Jan 14, 2026 | 05:58 AM
apache84's Avatar
apache84
Its 50mA is considered normal by todays electronic vehicles. Your 100% sure you havent woke up the BCM when checking. Sitting idle the seat pulls 65% of your normal max? that dont seem right, Why do it even pull anything Id be wondering.
Old Jan 14, 2026 | 10:58 AM
Jimmy's Pilot Service's Avatar
Veteran: Navy
My first look would be the alternator...
Pull the main feed and put the meter there on the main feed and the alternator lug. That diode tends to go bad and will be a draw point.
Truck asleep of course.
Also pull the hood lamp.
Old Jan 14, 2026 | 11:32 AM
99.5_Superduty
Yes I'm sure no waking up of any modules. Truck sat (with multimeter hooked up) for 2 hours before I got started. Everything went to sleep. There was no change in milliamps from the one hour to two hour mark. At two hours is when I started pulling fuses.
Seats are from a 2022 Grand Cherokee. There is a crazy amount of wiring on it. There are numerous modules on it for memory of seat position etc. It could be in the Cherokee these modules are forced to sleep -not sure.
To make sure that reading is correct, I will run the parasitic drain test again and this time once all is asleep I will disconnect the seat connection from the truck. If the reduction in milliamps is the same then that will confirm. Looking at the truck wiring diagram the seats look to be the only thing in that circuit.
The seats are easy to confirm and I can put a main switch on it if needed.
The ignition circuit is a bit more complicated, at least in my head.
Old Jan 14, 2026 | 11:34 AM
99.5_Superduty
After reading my test results why would your first look be the alternator?
I was able to get down below 50 milliamps with the alternator connected. How can the alternator be an issue?
Hood lamp was removed for testing.
Old Jan 16, 2026 | 04:25 AM
apache84's Avatar
apache84
When I read jeep cherokee I cringed. After 15 jeeps, two of them GC's, I will say NOTHING Ive ever owned were more electrically problematic that those 2 GC's. Problem #1, parasitic draw from junk switches and sensors. Unplug 100% of the power to the seat and see what you get.
Old Jan 16, 2026 | 08:56 AM
99.5_Superduty
Unplugging the seats = 32 milliamps. About the same as pulling the maxi fuse. The seats have lots of modules and wiring (heated, ventilated, 16 way power adjust with memory and massage).
I can install a main switch to shut off the seats. Or I can simply unplug them if the truck is going to sit for a long time.
Old Jan 16, 2026 | 08:58 AM
99.5_Superduty
Old Jan 16, 2026 | 02:26 PM
1987cabplus's Avatar
1987cabplus
I'd place a modest wager( GEM box) is toast.It starts to fail it will do all kinds of screwy stuff, Including drain the battery.Being a 99 this is a clear indication its jacked up.Even though the 98 f250 I fixed( Gem box) had zero water intrusion, or blemishes on the board,it was done.As soon as I replaced Radio worked,4x4,no batt drain, or stuff coming ON Key not even in the ignition.Takes maybe 30 minutes to swap, Easy it really is.
Old Jan 16, 2026 | 02:51 PM
99.5_Superduty
Pardon my ignorance, but what screwy stuff are you referring to in my situation? Why are you betting my GEM is bad? My GEM is using 8-9 milliamps, is that too much. Nobody has suggested that is too much power. Every electrical component works perfect in my truck. I am just trying to figure out if I have too much drain.
Old Jan 16, 2026 | 03:18 PM
1987cabplus
My goof! I just saw the draw and it mimics things to a degree of a gem issue.The power seat draw does seem high.Will see if I can offer a better check or correction.
Old Jan 16, 2026 | 03:29 PM
1987cabplus
Just a little researching.Apparently the seat switch and or motor is staying on,pulling current.And as mentioned the diode on the alternator.Hope this a better suggestion!
Old Jan 17, 2026 | 06:30 AM
apache84's Avatar
apache84
Id google jeep GC seat causing parasitic draw. Its likely no uncommon and you may find its one specific part causing the issues. On either of my CG's it was sensors in the hatch where there are IIRC, 5-7 different sensors which caused the BCM to not be able to go to sleep. The battery would be dead after a few days or barely cranking after 2 days.
Old Jan 17, 2026 | 09:50 AM
1987cabplus
I would simply unplug the motor and see if the draw goes down.If no change unplug the switch to see the same.Should isolate between the 2.
Old Jan 17, 2026 | 02:21 PM
99.5_Superduty
Unplugging the seat reduces the milliamps the same as pulling the fuse. Now just looking at the circuit associated with the ignition switch.
rmorman
Apr 8, 2023 08:28 PM
Marco-Heavy
2014+ Transit
Jul 3, 2022 09:29 PM
speakerfritz
Nov 23, 2021 12:51 PM
Greywolf
All Things Towing
Apr 26, 2009 08:35 PM
rprice32
15
Nov 4, 2004 08:34 AM
