Kill switch?
Old Jan 13, 2026 | 12:47 PM
eagleflyer's Avatar
eagleflyer
Kill switch?
What is the best way to run a kill switch on these newer trucks? 2024 f250
Old Jan 13, 2026 | 01:43 PM
seijirou's Avatar
seijirou
What are your requirements? Should the truck be completely dead? Should it seem like normal except not crank? Should it crank but not start?
Old Jan 13, 2026 | 09:07 PM
eagleflyer's Avatar
eagleflyer
I guess more thought on this... I think it is good enough for the fuel to be shut off so it won't start. So just a hidden toggle switch.
Old Jan 13, 2026 | 09:44 PM
chadstickpoindexter's Avatar
chadstickpoindexter
If it's a diesel, I wouldn't personally want to shut off the fuel to it...
Old Jan 14, 2026 | 05:38 AM
Midwest87's Avatar
Midwest87
Cut the S terminal wire on the starter, with a switch somewhere.
You could likely get it by the fuse/relay box.
Old Jan 14, 2026 | 05:58 AM
99powerstrokedF250's Avatar
99powerstrokedF250
This is the simplest way to deac a vehicle that SHOULDN'T set a CEL.
Other option would be a kill switch on the main power wire to the starter, as that doesn't go through any modules but runs direct from the battery. But then you've either got to hide it in the fenderwell or under the hood somewhere.
At this point though, it's getting to be not worth it - you pay insurance on the thing, let them take it.
Old Jan 14, 2026 | 06:32 AM
eagleflyer's Avatar
eagleflyer
6.8 gas
Old Jan 14, 2026 | 06:40 AM
eagleflyer's Avatar
eagleflyer
I agree with that,Especially since I would make quite a bit of money since I bought it totaled. However, I looked for this truck for months because it is kinda rare, extended cab (didn't want 4 doors to limit length but still room for my tools and such) Red color since most were black or white, not for me. Now i want to start customizing with accessories and it would be very inconvenient for it to go away. I'm looking to get a size bigger tires, etc, etc.
Old Jan 14, 2026 | 06:41 AM
saratoga2011's Avatar
saratoga2011
If someone wants to steal it, they're going to steal it. I would not hack into or let anyone else hack into the factory harnesses.
Old Jan 14, 2026 | 09:09 AM
seijirou's Avatar
seijirou
The fuel pump fuse is in the fusebox under the hood. Pinpoint the location of that fuse then unbolt the fusebox and flip it over to find the wire going to that location. Snip that wire to run through your switch.
Old Jan 15, 2026 | 02:04 PM
MadMaxx84's Avatar
MadMaxx84
https://41twentytwo.com/product/vehi...-tjSDetGZanM-w
Diesel_Brad
Jan 16, 2026 12:19 PM
explorer003
Mar 11, 2022 09:46 AM
Skorpion007
Jun 15, 2020 10:01 AM
fzeed
13
Feb 18, 2009 04:06 PM
