Overall, that rust isn't concerning and doesn't condemn the unit. However, it might need some servicing such as points/cap/rotor/condenser, checking on the advance mechanism, a little lube here or there. Also there is the overall timing, plug wire order and so on... Let us know what you need some help with.
What causes you to look at the distributor?
I had this rebuilt last year. Just getting back into trying to get it running. I had someone come and take a look at the engine last Spring. I need to get the distributor timing squared away. When I opened the hood I noticed the distributor cap off and the rust.
I also bought the ez wire kit so I have some work to do.
I wouldn't worry about it too much. The components look new.
Take a look at the contact points, clean them up if needed, check the settings and call it good
Others will chime in and say if it is a bad idea but take the condenser, rotor and points off and put it upside down in Evaporust or rust 911 or citric acid and washing soda. It won't damage the metal or plastic components. I would just not put it deep enough for the bearing area to be submerged.
24 hrs it will look as good as news and then spray it down with your favorite rust preventive oil like fluid film or Gibbs oil etc. I am partial to Gibbs oil for this application.
This link provides some information on Evaporust, Rust 911 and the citric acid washing soda combination. They are all chelating agents and have a PH of around 4 which is the same as a tomato so the do not eat the metal or acid etch.
Separately on removed the points and condenser and went with the Pertronix "electronic ignition " module. Plugs and play, takes 10mins.
No adjustments to be made ever and runs like a top. A little pricy (cheaper on Summit Racing) but you don't have to worry about adjusting points or humidity etc. Less to break and adjust especially on longer trips.
There is absolutely no reason to remove the service/flash rust from the ignition components inside the distributor. They are not seen and they get replaced at the next tune-up. As already stated verify the advance mechanism is not locked up, lube the shaft, pivots (for the weights) and the cam for the rubbing block. Then send it down the road. If the OP is concerned with aesthetics he could pull the dist and clean the case and even paint it, if so inclined.
Left the cap off the distributor. Is this shot now with all the rust?
I have restored old Harley's like this for years and once cleaned up, with new points, condenser and rotor they work just fine. Of course HD doesn't use a rotor, but rest of the parts it does. Clean it up and run it.
My first 223 in my '56 f100 died a few years ago so I prepped a second 223 from my back yard. The dist on it had the cap on and looked clean throughout. I took it off and it spun with a little bit of drag compared to the dist on my daily driver of 12 years--this was not a surprise.
I decided to leave the second engines dist on it as I pressed it into service.
A few weeks into driving the freshened engine the timing didn't seem right. The mechanical advance was gummy and not advancing correctly. I didn't remember that from my initial inspection.
I go to turn the dist shaft and it was very tight. That was definitely new.
I was afraid this resistance might ruin the gear teeth on my cam.
I pressed my dist from engine #1 back into service and moved on.
Just because an old dist first appears to work doesn't mean it will keep going.
