Distributor cap and rotor replacement
Old Dec 12, 2023 | 08:03 PM
Larry115's Avatar
Larry115
First off you all have been awesome helping me with my truck. Now my neighbor and I are going to replace the distributor and rotor. Is there an easy way to get this done? Here’s my truck…
Larry
Old Dec 12, 2023 | 08:41 PM
FlyJSH's Avatar
FlyJSH
Veteran: Navy
The short answer is to remove the cap with the wires still attached by flipping off the two metal clips.
Swap out the new rotor. I put put a tiny dab of dialectic grease on the center top contact/button to lube the contacts. That said, in some circles, dialectic grease has no business in the cap.
Put the new cap on and clip it in place.
Transfer the plug wires ONE AT A TIME starting from one of the clips and working around the circle.
Now, the long part...
Crank the engine, and it should fire right off. If it doesn't, the wires are likely one installed plus or minus one of where they should be. If that is the case, move them all one clockwise (why clockwise, why not). If it still doesn't start, move them all one counterclockwise (where you originally had them). Try cranking again to be sure the first non start wasn't a fluke. Then move them all one counterclockwise one more spot. If all you did was change cap and roter, it will start.
Old Dec 12, 2023 | 08:53 PM
88n94's Avatar
88n94
Are you replacing the whole distributor or just the cap?
Old Dec 12, 2023 | 10:25 PM
kr98664's Avatar
kr98664
Originally Posted by FlyJSH
Swap out the new rotor. I put put a tiny dab of dialectic grease on the center top contact/button to lube the contacts...
Ford's official instructions:
https://www.ford-trucks.com/forums/1...tor-rotor.html
Note they said to put the dielectric compound at the tip only, and not the center contact.
Old Dec 13, 2023 | 07:28 AM
Larry115's Avatar
Larry115
Sounds easy enough thank u
Old Dec 13, 2023 | 07:32 AM
Larry115's Avatar
Larry115
Here is what I’m replacing…
Old Dec 13, 2023 | 07:35 AM
Larry115's Avatar
Larry115
Thank you…I’ll grab some dialectic grease today
Old Dec 13, 2023 | 02:05 PM
Max Capacity's Avatar
Max Capacity
Which engine do you have ?
Notice a lot of us have that info in our "signatures" in every post.
You can do that from the "edit signature" in the menu. Click on the arrow next to your name in the upper right corner.
Old Dec 13, 2023 | 06:06 PM
Larry115's Avatar
Larry115
I’ll do that now thank u. 1985 F350 with a 460
Old Aug 28, 2024 | 07:13 PM
3b-F100's Avatar
3b-F100
1st Gear
Hi, I'm replying to an earlier thread from December in hopes that some of you will see it. I have a recently purchased 1972 F100 302 and doing a basic tune up, etc as well as other parts. I went to replace the distributor cap and rotor - currently it has a red top and white/grey base. Replacement cap + rotor are nothing fancy - WVE stock replacement. After removing the existing cap I could not get the new one to line up with the base so that the closing tabs would be in the correct position. It was catching on the edge and I believe it was hitting the condenser screw below. Anyone had this issue? It seems like it should be a simple install ... thanks.
Old Aug 28, 2024 | 08:20 PM
FuzzFace2's Avatar
FuzzFace2
First welcome to FTE
Second you posted this in the wrong truck year area as our trucks dont have points & condenser.
Note the cap only fits the dist. base one way. Look at the bottom of the cap and you should see a notch.
Now look at the dist. base and it should also have a tab to fit the notch.
I also dont think the points & cond. can be installed right and stick out the side.
Do you have uni set points or point & cond. 2 parts?
If lining up the cap notch / tab dose not get it to fit right post up a picture or 2 of what you got so we can see what you are talking about.
Dave ----
Rusty Bucket Ohio
Jul 23, 2023 10:42 PM
kr98664
Apr 20, 2021 02:28 PM
Jlaviena
Nov 1, 2020 04:39 PM
ScottyC50
Dec 31, 2018 11:41 AM
68murc
Nov 14, 2015 08:09 PM
