6.0 Superduty Steering Gear Problems
Old Feb 12, 2026 | 07:21 PM
  #31
Fuzzpuss's Avatar
Fuzzpuss
Originally Posted by wpg_250
I did a bit of reading and some people say that a 2008+ steering gear will hit the frame on a 99-04 before it locks out so not sure if that's an issue or not, also not sure the placement of everything with the front leafs being there so maybe that PSC box is the way to go
Well, my 2.5 year old Blue Top just started groaning, grinding, and ratcheting at full lock to the left, so I am suddenly and unwillingly in the market. Before shelling out the stupid coin for the PSC unit, I am going to mock-up a gear from an 06 and see if there are any clearance issues. If it's a no-go then I'll be ordering a PSC as soon as I am able to afford it. Now that the ported option is only an extra $50, I wonder if a steering assist would be worth it with barely bigger than stock tires (285/75R16). Maneuvering this pig in parking lots does take a lot more effort than it seems like it should.
Old Feb 13, 2026 | 09:17 PM
  #32
wpg_250's Avatar
wpg_250
I'd definitely be interested in knowing how it goes.
Old Feb 23, 2026 | 02:12 PM
  #33
TooManyToys.'s Avatar
TooManyToys.
https://www.skysoffroaddesign.com/pr...31ec3722&_ss=r
This business makes tapered sleeves to repair worn pitman arms. Using a mill to bore out the old taper to just under 1”, you chill the sleeve and heat the bored pitman arm, then press it in. Then heat up the arm and TIG weld them together.
They might have them to rework the later arms that fit the later Ford box to fit the ‘99-04 tie rods.
Old Feb 23, 2026 | 10:54 PM
  #34
Fuzzpuss's Avatar
Fuzzpuss
I like the way you think Jack, but there is still the difference in length of the pitman arms (03 being longer) to deal with.
Old Feb 24, 2026 | 08:30 AM
  #35
TooManyToys.
Yes, I know, but the gear ratio is also a factor in the pitman arm length, as well as the length of the arm at the knuckle. Ford played a lot with this in the early years, 99-04. Boxes, too. Just because the pitman arm has a different length does not mean it has the same leverage and degree to turn of the knuckle.
Old Feb 24, 2026 | 09:36 AM
  #36
texastech_diesel's Avatar
texastech_diesel
Token Redneck
You doing anything to the rest of the system or just change the steering gear out? I think my dually box has problems. Feels like zero power steering but the brakes work fine, running stock 17s so basically the smallest tire they put on these.
Old Feb 24, 2026 | 01:40 PM
  #37
Fuzzpuss's Avatar
Fuzzpuss
Well I guess we'll find out when I install the 06 gear. Gonna be a few weeks though.
Old Feb 24, 2026 | 02:11 PM
  #38
Fuzzpuss's Avatar
Fuzzpuss
I have already replaced everything but the cooler, which is why I am considering getting a ported gear, because one day I just may decide to try the cylinder assist, or will a brand new gear make all the difference?
It was definitely easier to maneuver with the stock sized radials that came on the truck; and also easier with the Toyo's which I believe was due to harder rubber compound than the KO3's.
It does stand to reason that if the flow is good enough that the brakes still work well, the gear would be the weak link. I am sure Jack has something to say about that.
Old Feb 24, 2026 | 02:36 PM
  #39
wpg_250's Avatar
wpg_250
You're putting a stock 06 steering box on your 04 🤔
Old Feb 24, 2026 | 04:34 PM
  #40
Fuzzpuss's Avatar
Fuzzpuss
We went over this nine posts ago. It's for testing. Though I don't have high hopes.
Old Feb 24, 2026 | 05:29 PM
  #41
wpg_250's Avatar
wpg_250
Oh yeah lol
Lockholder
Dec 5, 2020 09:11 PM
Supercoltsfan
Feb 15, 2018 09:12 PM
OUTATIME
May 17, 2017 09:28 PM
mrkyancey
Dec 4, 2012 04:24 PM
itsjustagreat1
Jan 31, 2009 12:02 PM
