“Clacking” on Throttle
Old Jan 10, 2026 | 08:30 AM
defdes's Avatar
defdes
I’d been noticing more engine noise than I’m accustomed to, I replaced my shifter boot, which helped a bit and I thought the noise was engine noise from my leaking up pipes. I replaced those with bellowed and the noise is still there. All under hood hoses have been replaced and are tight. Perhaps I’m nuts and just realizing how loud these trucks are, but have a listen and tell me what you hear:
Old Jan 10, 2026 | 06:58 PM
97-psd's Avatar
97-psd
Hard to tell on a phone but low fuel pressure can make it louder as well. Might check it to make sure.
Old Jan 10, 2026 | 08:47 PM
defdes's Avatar
defdes
Point taken. Maybe I’m starting to get a restriction from the tanks (dread). I was in replacing up and down pipes and noticed the fuel pump leaking so just replaced it with an OEM lifter pump. Noise was the same as before all of the work.
Old Jan 12, 2026 | 09:34 AM
knottyrope's Avatar
knottyrope
almost sounds like when my HB went out
Do you have any run out on yours?
Whats you belt look like?
Old Jan 12, 2026 | 05:37 PM
defdes's Avatar
defdes
Pulley is tight, Belt is beginning to show wear on engine side but has been on there for a few years. Before I changed to OEM tensioner/guide wheel I was going through belts at an alarming rate .
Old Jan 13, 2026 | 08:52 AM
knottyrope's Avatar
knottyrope
That sounds like HB is worn, with it running, go under and put a piece of this wood next to the pulley and see if it wobbles at all.
Old Jan 13, 2026 | 10:50 AM
defdes's Avatar
defdes
You said “HB” and I went straight to “HydroBoost” and its pulley. You are correct, by balancer is a bit out and I have a new OEM replacement ready to go on this weekend along with the LVLP Mehling upgrade. I’ll update when the job is done. Does the fan clutch have to be removed for both of those?
Old Jan 13, 2026 | 03:36 PM
Hit Man X's Avatar
Hit Man X
Yes, pull the fan. I have data about me doing the Fluidamper swap with the Melling in my thread
Where did you procure the balancer?
Old Jan 13, 2026 | 05:57 PM
defdes's Avatar
defdes
Thanks… I hate renting tools.
I THINK I got it from RiffRaff, I’ve ordered from all over over the last month, but 80% of the parts came from them.
Old Jan 14, 2026 | 12:26 PM
Hit Man X's Avatar
Hit Man X
I purchased a larger Gearwrench brand fan clutch kit, tired of renting also. I also own their serpent belt tool set
Old Jan 14, 2026 | 05:07 PM
defdes's Avatar
defdes
Today I noticed a large bicycle headset wrench welded to a piece of flat stock in my shop, I think I must have made that when I had the fan off last time. Anyway , what does that Gearwrench serpentine belt kit allow you to do that you can’t do with a 1/2” breaker bar?
Old Jan 17, 2026 | 07:06 PM
defdes's Avatar
defdes
All done with the new balancer and LPOP and that did it. So much more pleasant to drive now, smooth and quiet, well 7.3 quiet anyway.
Old Jan 22, 2026 | 11:24 AM
97-psd's Avatar
97-psd
Glad it worked for you. Got another video so we can hear the difference?
Old Jan 22, 2026 | 11:31 AM
Hit Man X's Avatar
Hit Man X
https://www.gearwrench.com/all-tools...ch-service-set
That is what I picked up, works on many of my vehicles. Sure auto store ones free rental, still takes time to go there!
Good to hear you are back in business.
Old Jan 22, 2026 | 01:44 PM
defdes's Avatar
defdes
PSD fans ask and I shall provide:
before:
after:
”Ticking” sound being discussed in another thread.
Waco-kid
2015 - 2020 F150
Jul 8, 2025 01:36 PM
caprisecca
Jun 28, 2013 02:47 PM
Cowboy68
Jun 12, 2002 06:05 AM
