Hard shift E40d
Old Jan 9, 2026 | 06:54 PM
Davon3598's Avatar
Davon3598
Hard shift E40d
I have a 96 F250 7.3 I acquired for free. It has a harsh 1-2 up shift and 4-3 downshift. The truck has no transmission codes. It has led tail lights and third brake light which I plan to swap out just in case it’s contributing. I do have a P0107 code for baro sensor. Can that affect transmission? It went away for like 3 days and now it’s back.
Old Jan 9, 2026 | 07:40 PM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
What are you using to read the codes? Many code readers cannot read Ford transmission codes.
Old Jan 9, 2026 | 07:47 PM
Davon3598's Avatar
Davon3598
this one below. vLinker FD+
Amazon Amazon
Old Jan 10, 2026 | 04:05 PM
Mark Kovalsky
I don't know if that will read them or not.
I recommend unplugging the TRS and see if a code sets for that.
Old Jan 10, 2026 | 05:00 PM
Davon3598's Avatar
Davon3598
Good point I didn't even think about that. I unplugged the TRS and it did set off the code (P1705) but I had to run the KOEO self demand test for it to show. I also see P0107 and P0470. P0470 I checked the EBPS and its clogged big time. Unsure if those codes are related to my issue. Wanted to cover everything possible before dropping transmission.
When I acquired the truck that transmission had no gears so I dropped it and replaced it with an E40d my buddy had. I reached out to the old owner today and he said the last E40d that was in the truck had a hard 1-2 as well. This could be a coincidence but unsure at the moment.
Old Jan 10, 2026 | 08:27 PM
Mark Kovalsky
It could be a stuck accumulator valve in the accumulator body.
Old Jan 11, 2026 | 03:40 PM
trackspeeder's Avatar
trackspeeder
I would change the LED lights before going crazy on the tranny.
Old Jan 11, 2026 | 04:36 PM
Mark Kovalsky
I can't see how LED lights could affect the transmission shifting.
Old Jan 12, 2026 | 05:29 PM
trackspeeder
Something about LED lighting with the OBS trucks.
When LED lights are installed the transmission acts up.Specially the 1-2 shift.
Return to the standard bulbs everything returns to normal.
Old Jan 12, 2026 | 06:31 PM
Davon3598's Avatar
Davon3598
Going to replace the third brake light and tail lights. I don’t care for the LED anyway. Replace the BARO to see if that code goes away and then drop the 1-2 Accumulator body and see if it’s broken. If so good accuse to reach out to BTS and get one from them. Will keep this updated.
Old Jan 13, 2026 | 08:50 AM
knottyrope's Avatar
knottyrope
LED lights can prevent TC lockup as the PCM wont see a ground applied and TC lockup can be confused with a gear shift to some.
Loftatsea
Jan 6, 2025 10:05 AM
twfs
15
Aug 28, 2008 07:29 AM
mohle
Sep 3, 2007 08:04 PM
Piffery1
1983 - 2012 Ranger & B-Series
Sep 10, 2004 11:19 AM
trsest1
Apr 1, 2004 10:23 PM
