Aerostar Ford Aerostar
rack and pinion.
Old Jan 9, 2026 | 03:56 PM
zenish's Avatar
zenish
rack and pinion.
does anyone ever change the seals in there?
Old Jan 10, 2026 | 02:48 PM
DFord's Avatar
DFord
I bought the whole rack and pinion when I had leaks.
These links are for a 1997 Aerostar. Your "About" information says you've got a 1962 so it won't be much help.
Here's a listing at RockAuto for a kit:
https://www.rockauto.com/en/catalog/...+seal+kit,7396
or, here's the whole rack and pinion assembly:
https://www.rockauto.com/en/catalog/...nd+pinion,7388
Old Jan 10, 2026 | 08:03 PM
zenish's Avatar
zenish
thats my old van.this is a 1991 xlt.i actually have a rebuilt unit in the attic from rock auto but i hear nothing good about the rebuilt units.mine works fine but is drip drip drip.the molasses lucas fluid worked great for a while.
Old Jan 11, 2026 | 09:49 PM
DFord's Avatar
DFord
Give replacing the seals a try and see what you think.
Let us know if you think doing that would be any easier than replacing the whole rack and pinion.
Old Jan 12, 2026 | 03:55 PM
xlt4wd90's Avatar
xlt4wd90
I would think that replacing the seals will be more work than just replacing the rack. You have to remove and install the rack, but in between, you have to rebuild the rack.
If the rack parts are not worn out, it's worth rebuilding. In other words, the new seals need to be able to seal against good surfaces. If the rack itself is worn out, the new seals will not fix that. If the wear is not too severe, the worn rack may be re-surfaced, but may require special tools to do that.
This may be the problem with so many rebuilt racks; they just replace the seals on racks that may already be too worn.
Kelyn Brown
Jul 19, 2016 11:52 AM
thewestie
May 22, 2014 12:23 AM
allen720
Florida Chapter
Apr 13, 2012 07:47 PM
xlt4wd90
Dec 13, 2010 04:13 PM
1 bad 300
Apr 14, 2004 08:16 AM
