EBPV Delete Q
Old Jan 9, 2026 | 02:03 PM
defdes's Avatar
defdes
EBPV Delete Q
Should I snip the connector off the old EBPV tape off the wires and plug it into the harness? Would that eliminate the soft code or should I just tape off the female connector on the harness?….OR is it NBD either way?
Old Jan 9, 2026 | 02:34 PM
knottyrope's Avatar
knottyrope
Jut unplug and tape up, soft code only shows on scanner.
99 and higher need a resistor to stop CEL light.
Old Jan 9, 2026 | 07:51 PM
defdes's Avatar
defdes
Cool, thank you.
Old Jan 17, 2026 | 02:00 PM
TheFecalFanatic's Avatar
TheFecalFanatic
I used a carriage bolt and washer set up on my OEM turbo for years. Was an awesome cheap delete lol.
You can buy the resistor if you want, I ran one before but just snipped it out. Like stated it's only a soft code.
Old Jan 17, 2026 | 07:56 PM
defdes's Avatar
defdes
Nice, turns out the PO had disconnected the EBPV rod and filled the outlet and I didn’t notice as I didn’t know never what to look for. Pedestal was leaking like a **** though and if the turbo ever needs to come off again, the delete pedestal makes the 8 bolts so much easier to access.
Old Jan 18, 2026 | 06:01 PM
TheFecalFanatic
T4 makes the turbo removal even easier.....
Old Jan 18, 2026 | 06:38 PM
defdes's Avatar
defdes
Thats a cool set up, maybe next time!
Charmalu
13
Mar 28, 2022 02:14 AM
Randy Sheats
May 20, 2017 07:18 AM
dmanshane
Dec 31, 2011 12:59 PM
Fullcrew7.3
33
Jul 18, 2011 07:53 PM
weekendwander
May 21, 2007 10:56 AM
